'61 Ampeg R12-R Hum
  • '61 Ampeg R12-R Hum
    Constant hum, volume control has no effect on hum. Removed PI(no hum)
    Removed 6SL7's/6SN7's
    Reinstalled
    V4 socket only with any of four(4) tubes has hum.
    Amp appears to be original except 3 prong power cord, death cap removed, and 2 caps shown in photo. All tubes are Sylvania.
    Reinstalled
    Meant for title to read Ampeg R-12R(Reverbrocket)
      schematic attached
        Originally posted by g1 View Post
        schematic attached
        Thanks, the two resistors soldered to pins 3 & 6(220k & 1k) are good. Issue with this amp is hum is too loud for recording but is in good operational condition otherwise.
          schematic attached
          Im seeing a cap set on fliptops. Would rather find the exact issue though.
            What is the current draw on the output tubes? They should be pretty close
            nosaj
              nosaj
              V5(47mA)
              V6(27mA)
              Using a eurotubes bias adapter.
                Well there you go possible hum with unbalanced tubes.
                Nosaj
                  ✓-appreciate the help. Will install different 6v6's and retest.
                    Nosaj
                    Didn't have a spare 6V6 so used two(2) 6L6's. Now V5(51 mA)
                    V6(51mA)
                    Hum is as loud if not louder at this point.
                      Do you have a scope?
                      nosaj
                        nosaj
                        PC based.
                          Have you scoped the signal from the PI to the speaker out? I presume you know how to properly do this?
                          nosaj
                            nosaj
                            Can you elaborate?
                              Here is some reading for you.
                              nosaj
