Anybody have a schematic for a Boss PS-2? I have a really bad volume drop for the delays, while the pitch shifting section is fine.
Boss PS-2 schematic
This is the First edition.Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
Were you able to find the reason for the volume drop with your PS-2?
I have a similar issue with mine. With balance at noon the first repeat is the same volume as the dry signal, but I only get five or six audible repeats even with feedback at max. Output from pitch shifting modes seems fine
I should also add that I'm almost certain that the feedback has reduced since I bought the pedal. I was underwhelmed when I first got it but now I reckon that it was failing when I bought it and has got progressively worse. Was yours ok in the past?Last edited by james0113; 01-16-2024, 03:46 PM.
Originally posted by james0113 View PostWere you able to find the reason for the volume drop with your PS-2?
