Boss PS-2 schematic
  • Boss PS-2 schematic
    Anybody have a schematic for a Boss PS-2? I have a really bad volume drop for the delays, while the pitch shifting section is fine.
    This is the First edition.
      Were you able to find the reason for the volume drop with your PS-2?
      I have a similar issue with mine. With balance at noon the first repeat is the same volume as the dry signal, but I only get five or six audible repeats even with feedback at max. Output from pitch shifting modes seems fine
      I should also add that I'm almost certain that the feedback has reduced since I bought the pedal. I was underwhelmed when I first got it but now I reckon that it was failing when I bought it and has got progressively worse. Was yours ok in the past?
        Unfortunately no. Every so often I go at it again trying to find the issue but I'm not sure what it could be. I really thought it would be the electrolytic capacitors as some of them tested poorly, but swapping didn't change the problem.
        holiganbet betturkey
