Emg 81x 85x not working
  • #16
    Originally posted by SeanDoesGuitar View Post
    Actually, the link is here.
    If you scroll down to page 3 , its figure 6B
    http://www.emginc.com/content/wiring...0230-0110D.pdf
    There has to be something wrong with the volume pot module. Everything plugs in, so it's not a soldering issue, and that wouldn't effect the volume pot.
    I'd return it and get a new one.
    http://coneyislandguitars.com
    • #17
      I live in Canada and ordered it from the states, the thing I don't get is that it came with 2 separate pickups, each with it's own jack, volume and tone pots as well. I tried both with the same issue. Ya, the toggle switch works fine, I've tested with the sound on. I'm going to try replacing the battery.
      • #18
        What about board? How do the traces and solder look on the connection board? If the two pots do the same thing, a common element is the board.
        -Mike
        • #19
          What do you mean the board? All the wiring is connected to the buss, as shown in the first picture, no soldering required just plug and play.
          • #20
            Buss, board, same thing.
            -Mike
            • #21
              I can't spot any solder on the buss. As well I tried both connections on the 2 busses that came with the pickups with the same results. People are telling me to just take it to a guitar tech, but I don't see how they are going to do anything different then following the diagram that was provided.
              • #22
                From the diagram, it looks like the shield(S) and the tip(T) on the jack socket are labelled wrongly and need to be swapped.
                • #23
                  You are a life saver man. It worked. Think I should notify EMG tech support of this?
                  • #24
                    Glad about that.
                    Surely they must be aware of it, but I'd just wait until they phone you up
                    • #25
                      Glad about that.
                      Ya lol, just happy it's fixed. Saved me over 100$.
                      Cheers!
                      Thanks for the support everyone, been liking this forum since day one .
                      • #26
                        They are saying that the white wire is signal and the black wire is ground.
                        Look at diagram #4
                        If that's the case, that matches the other diagram, where black goes to sleeve (S) and white goes to tip (T).
                        That sounds like someone else might be plugged in backwards.
                        • #27
                          You could be right there.
                          I just took the mottled "white" wire to be the screen in the diagram...
                          I was quite excited about it.
                          • #28
                            I thought it was as well, until I went to the other PDF and started reading it.
                            I see in the instructions that one connector on the tone control is reversed on purpose. I'm not sure why.
                            • #29
                              So I shouldn't be installing the jack, putting all my strings on and play just yet?
                              • #30
                                If it seems to be working, then it's working.
