One volume control, two pickups - one at 250K, one at 500K.
    Hmm, well that sounds pretty unpredictable, something to probably be avoided. It would not reduce all frequencies then, just the highs apparently.
      Volume reduction depends on amp input impedance.
      Treble cutoff could be roughly calculated if cable capacitance is known.
      But in your case it's a matter of minutes to find out what you like better, series or parallel resistor.
        No, I'm happy with it the way it is now. I'll stick. Thanks for indulging me though.
          All started from #3
          I'm trying to get 250K on the bridge and 500K on the neck.
          It's All Over Now
