How Does Tension effect sound and output?
  • #16
    Originally posted by Possum View Post
    I don't think its optical those are stainless steel slugs, the fatter core is on purpose, I spotted that the first time I saw that thing. There is way more clearance away from the slugs than conventional buckers.
    If you really want to nitpick, it's actually the screw coil that looks a bit fatter in that picture.
    • #17
      Originally posted by frankfalbo View Post
      Not according to the website...
      Gibson - Gibson USA: Zoot Suit SG Electric Guitar, images, videos and detailed specs,
      My favorite quote:
      "The wire used in these pickups is made from polysol copper...It is the same wire used in pickup manufacturing in the 1950s and 1960s."
      No, the BEST quote on that page is:
      Frets
      The traditional “medium/jumbo” fret wire is a combination nickel and silver alloy (approximately 80 percent nickel and 20 percent silver) specifically designed for long life and superior wear. After hand pressing it into the fingerboard, a machine press finishes the job to eliminate the gap between the bottom of the fret wire and the fingerboard.
      The person who wrote the copy on that page doesn't know a damn thing about much of anything, and certainly not guitars.
      There is no silver in nickel silver, and it's not 80% nickel. It's generaly 60% Copper/ 20% Nickel/ 20% Zinc.
      Here... just for fun, I did some Photoshop work on that photo.
      First I corrected for the perpective distortion, then you see the two coils super imposed on top of each other. Looks like the screw coil is fatter.
      http://coneyislandguitars.com
      • #18
        Yeh you're right the coil formers are the same size, the screw heads are are the same diameter as the slugs. Winds are equal. The black tape on the upper bobbin is optically making it look different. Anyway, its one pickup I won't be buying to back engineer :-) I thought it was kind of a mistake the writer posted what alloys are used, I wonder if Gibson even read it :-) Still, its an intelligent design, there is a reason there is so much space between the coils and the poles....
        http://www.SDpickups.com
        Stephens Design Pickups
        • #19
          Do you suppose Gibson really cared about tension so much back in the day? What do you suppose was the tension used on the PAF's?
          • #20
            The screw heads are larger than the slug. David Photoshopped it at the top of the slot so the widest part of the screw is not in the photo.
            They don't make them like they used to... We do.
            www.throbak.com
            Vintage PAF Pickups Website
            • #21
              Yes, when I had them overlapping, the screw head was larger.
              • #22
                Which anyone who has ever tried to drill out a screw bobbin for slugs or strat magnets knows...
                • #23
                  I think its really cool youre here frank.
                  ML
                  • #24
                    Frankfalbo reveals yet another closely guarded Seymour secret....
