Building Jazz Bass pups
Very nice video! Your potting scares me though, I used to do the double boiler method like you but somehow it flashed and caught fire, second degree burns on a few of my fingers...wasn't fun at all! I know you know what you're doing but Murphy can strike anyone!
What I do for potting is to use a paraffin warmer thats intended for people to stick their hands in. They are not expensive, come with wax, and can safely be left on 24 hours a day, not that I see a need for that. Once the wax has melted it regulates the temperature. I got mine from Amazon for about $30.
Nice video. Two things, there's no need to check your DC resistance while you are winding. Just wind to the same number of turns for that pickup each time and you are good to go.
And why is your wax so brown?Last edited by David Schwab; 09-21-2011, 02:45 PM.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Could These Video Post's be Moved to the Beginners Corner.
These Would be good references for Beginners to refer to.
Most of the Folks that hang in the regular Forum already Know most of what you Have Covered.
But, would be great for those of us Learning the Basics.
Good Luck,
B_T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by David Schwab View PostWhat I do for potting is to use a paraffin warmer thats intended for people to stick their hands in.
Originally posted by Jim Shine View PostYears ago I had to go through physical therapy and that was part of it, the "paraffin treatment". It was paraffin in one of those warmers with some sort of mint oil mixed in. You would dip you hands in, let them warm, remove, then peel away the wax.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
