How about a game....Name that Tool.
  • How about a game....Name that Tool.
ID:	967862 Click image for larger version
ID:	967863 I know what it is. Just thought a game was in order. If you have a odd tool . Join the game and keep it going.
    nosaj
    Looks like a wire wrap tool.
    https://makezine.com/article/technol...wire-wrapping/
    http://amps.monkeymatic.com
      Your no fun......Ok since you got it. You got post a tool.
      nosaj
ID:	967869 Click image for larger version
ID:	967870 Ok I'll try again.
        nosaj
          DIY vasectomy tool
            That looks like an end-pull wire stripper
              The first one was EASY, a wire wrap tool.
              The second one:if end is sharp it might be a flat wire stripper but I guess some kind of connector crimper.
              Might do both jobs, first expose copper ends and then crimp them inside a connector.
              I have used similar tools.
                Second one is a self-adjusting (to wire diameter) wire stripper (as Mick Bailey guessed).
                I have one of those, but don't use it anymore.
                Wire-wrap wasn't common in Europe so I didn't know the first one.
                  My contribution to the game. Click image for larger version
                    Here's an easy one (upper item): img.pdf
                      Probably an animal nut crusher.
                      nosaj
                        Not electronic related...
                        If it ain't broke I'll fix it until it is...
                        I have just enough knowledge to be dangerous...
                          Here's an easy one (upper item): [ATTACH]n967942[/ATTACH]
                          A stirrer and stopper for test tube or similar?
                            It's an official tube hammer used to test for microphony.
                            Mallet is rubber.
                            Admittedly not an essential tool.
                              I'll admit I cheated but it was to use a new tool. Google Lens is actually pretty cool.
                              nosaj
