Yamaha P-60
  • Yamaha P-60
    Does anyone have this piano service manual or schematic?
    Thanks in advance.
    Yamaha P-90 Service manual
    I have the P-90 S.
    I believe the 'S' indicates 'Silver' finish.
      I have the P-90 S.
      Thank you Jazz P Bass !!
        I can't get the link to work for the service manual download. Is there any chance you can repost it , as my P60 is playing up and I could do with seeing if there is a factory reset type function.
        Regards
        Coxy46
          Regards
          Coxy46
          Hello Coxy46:
            Yotico, you will need to put that file in a zip and post it as a zip or it will not work here.
              Here are 2 4 the price of 1. http://elektrotanya.com/yamaha_p-60s.../download.html
                Doc, that is the correct file in the zip (P-60S Yamaha), just letting you know you have the zip labelled as "PS60", which is a Korg model.
                  Thanks for the correction but unfortunately I came back too late to be able to edit my mistake... I knew there was an "S" somewhere in the name and then your brain just farts out when you go to type it out...
