I can't get the link to work for the service manual download. Is there any chance you can repost it , as my P60 is playing up and I could do with seeing if there is a factory reset type function.
Regards
Coxy46
Regards
Coxy46
Doc, that is the correct file in the zip (P-60S Yamaha), just letting you know you have the zip labelled as "PS60", which is a Korg model.
Thanks for the correction but unfortunately I came back too late to be able to edit my mistake... I knew there was an "S" somewhere in the name and then your brain just farts out when you go to type it out...
