A friend asked if I could mod his Neno Small Stone to produce the different exotic effects I can get on my Small Stone clone. Or rather, I said "If you like what mine can do, let me poke around inside yours and see if I can get it to do the same things".
Well, the problem is, the Nano series uses LM13700s, and surface mount components. That, in itself, is not THAT big a deal. The problem is, the only schematic I have for a dual-13700 circuit is from the early 80's, and it uses a quad LM324, while the Nano series uses two TLC2272 dual op-amps. and also changes the values of a a number of resistors, so pinpointing comparable parts of the circuit is difficult, if not impossible, o do.
I was hoping to be able to install a switch for producing vibrato, but I'll be damned if I can find the mixing node. All I've been able to find is this mod: EHX Nano Small Stone Mods - Distorque Audio although he also notes being stymied by the things I mentioned.
So, if you have a schematic, or simply know where the dry+wet mixing node is on the board, I'd be much obliged.
