Any info on Nano Series EHX Small Stone
  • Any info on Nano Series EHX Small Stone
    A friend asked if I could mod his Neno Small Stone to produce the different exotic effects I can get on my Small Stone clone. Or rather, I said "If you like what mine can do, let me poke around inside yours and see if I can get it to do the same things".
    Well, the problem is, the Nano series uses LM13700s, and surface mount components. That, in itself, is not THAT big a deal. The problem is, the only schematic I have for a dual-13700 circuit is from the early 80's, and it uses a quad LM324, while the Nano series uses two TLC2272 dual op-amps. and also changes the values of a a number of resistors, so pinpointing comparable parts of the circuit is difficult, if not impossible, o do.
    I was hoping to be able to install a switch for producing vibrato, but I'll be damned if I can find the mixing node. All I've been able to find is this mod: EHX Nano Small Stone Mods - Distorque Audio although he also notes being stymied by the things I mentioned.
    So, if you have a schematic, or simply know where the dry+wet mixing node is on the board, I'd be much obliged.
    The only tidbit that I found on the Nano mixer section:
    "The normal fixes for it wouldn't work anyway, because the boost and mixer sections have been replaced by opamp sections".
      The schematic for the dual-13700 version from the 80's shows an op-amp mixer section, rather than the traditional passive mixing of the CA3094 versions, so I'm okay there. I just can't find the damn thing!
        maybe you'll find something here
        http://www.mediafire.com/download/d31xf0pn2q3i1fn/eh_factory_schems.zip
        It's All Over Now
          Possibly. Can't access it from work. I was given a link before with a big archive of EHX factory schems, including a number of their more recent (though pre-2010) pedals, and it did not include the Nano SS. I'll just have to wait and see if this is the same archive or a more recent one.
          Thanks, either way, though. I appreciate your effort.
            Here is the file:
              Thanks. As suspected, it is the same one I had already snagged a few months back, and has the 5 x CA3094 circuit.
                Appreciated, but I'm not much further ahead. The content of the first link is actually the same as that of the third link.
                  https://sites.google.com/site/electroconducive/schematics
                  Old EHX Factory Schems
                  http://www.freestompboxes.org/viewtopic.php?f=1&t=3567
                  EHX - Small Stone ( LM13600 )
                  http://img.photobucket.com/albums/v517/uncle_boko/EHsmallst2.jpg
                  It's All Over Now
                    Uncle Boko is actually Stephen Giles, who sent me the earlier 13600-based schem you show. So, not any closer.
                    I think what I need to do is re-register at the EHX Forums and ask the folks there.
