I will be grateful.
VOX Westminister schematic
Originally posted by bsco View Posthere is a pic for you...this is the inside of the chassis...the model number appears to be V124...
Cheers
http://www.voxshowroom.com/us/amp/kensington_hood.html
https://music-electronics-forum.com/filedata/fetch?id=848609
https://music-electronics-forum.com/forum/amplification/guitar-amps/maintenance-troubleshooting-repair/20976-vox-kensington-v1242-g-tuner?t=20442
http://bee.mif.pg.gda.pl/ciasteczkowypotwor/%23SM_scena/VOX/
1)
V1241 Kensington is V124 Kensington with added a "G-Tuner"It's All Over Now
No AC187
AC187/188 is germanium transistors.
865075-2 or Q4 (transistor "G") is silicon transistor.
1)
http://www.voxshowroom.com/us/amp/v1011_hood.html
Power Amp Driver Circuit - The driver circuit included two transistors and a driver transformer. The power amp driver transistor (Q4) was designed to increase the gain in the preamplifier audio signal. The factory replacement part number for this transistor was 86-5075-2, but Thomas often refered to this transistor simply as "G." It was housed in a TO-3 style "top hat" case. As this part is susceptible to heat related failure, Thomas added cooling fins to the transistor (see circuit board photo at top of page). The industry standard equivalent part number for this silicon transistor is 2N2219.It's All Over Now
1)
Cheers,
The picture shows that Q4 cannot be AC187
The AC187 was installed by some quasi-forum expert
http://www.voxshowroom.com/ct/amp/us/kensington/kensington_chassis_inside_12.jpg
https://images.reverb.com/image/upload/s--yJDk0QL6--/a_exif,c_limit,e_unsharp_mask:80,f_auto,fl_progressive,g _south,h_620,q_90,w_620/v1451948912/fosmratxynulclhb9rv7.jpg
See Kensington Bass replacement parts scan0004.pdf for transistor Q4
Compare schematic for power amp (Q4) and read #21 note1)
https://music-electronics-forum.com/filedata/fetch?id=867925
Vox Pathfinder V1011 schematics 2)
Vox Kensington V124, V1241schematics 3)It's All Over Now
CheersExperience is something you get, just after you really needed it.
Please label transistors with "factory code" and possible replacement.
That TO5 Driver transistor can be replaced by an easy to find TIP29 or TIP31,or some NPN TO39 case with a minimal heatsink, a thumbnail size piece of aluminum, but make certain it reaches the PCB surface and glue it there.
Drop of contact-neoprene cement/silicone/even hot glue but thisthe is the least reliable because bumps can separate it from non porous PCB surface, a*little* elasticity is better.
The AC187 was certainly some forumhead idea.
"Hey, old VOX used germanium, so .... "Juan Manuel Fahey
Originally posted by nickb View Post
Any chance you can trace out the schematic for posterity please? It would also help giving advise on substitutions.
Cheers
- Likes 1
Finally getting back here to do an update....I apologize for the delay but unfortunately shit happens that has to be dealt with.....anyway, I ordered some TIP31's as J.M.Fahey had suggested....it worked out great.......I will give it another test next week and then get the owner to come and pick it up....Thanks to everybody for all their help......
Cheers
