working on a Behringer PMP1280s pa. found 3 shorted mosfets and current sense resistor blown out in side A power amplifier. customer plugged in to many speakers and overloaded amp. have located mosfet replacements on Jameco. need help with current sense resistor. do you have a parts list? found schematic on another post for 2x 400watt amp, the amp I'm working on is 2x600w amp. current sense resistor is marked '30m ohm F'. on schematic is R138 0E03. do you know where I can find a replacement? do you have copy of 2x 600w amp? thanks for any help
Behringer EUROPOWER PMP1280S
Yep.
.030 ohms surface mount
Search results for: .03 resistor 33 mOhms Current Sense Resistors - SMD – Mouser
thanks for helpful posts. found 3 blown mosfets, damaged current sensing resistor, open drain leads and shorted dual diode LD20U marked as D20 on print. having trouble locating this dual diode. any suggestion? would anyone
possibly have one they could spare? thanks again
D5LD20U is the part #.
https://music-electronics-forum.com/...611#post415611Last edited by Jazz P Bass; 07-20-2021, 01:59 AM.
