Behringer EUROPOWER PMP1280S
  • Behringer EUROPOWER PMP1280S
    working on a Behringer PMP1280s pa. found 3 shorted mosfets and current sense resistor blown out in side A power amplifier. customer plugged in to many speakers and overloaded amp. have located mosfet replacements on Jameco. need help with current sense resistor. do you have a parts list? found schematic on another post for 2x 400watt amp, the amp I'm working on is 2x600w amp. current sense resistor is marked '30m ohm F'. on schematic is R138 0E03. do you know where I can find a replacement? do you have copy of 2x 600w amp? thanks for any help
    I imagine it's probably 3 ohms by the markings. Maybe not. You have a stereo amp in front of you. Check the same resistor on the good channel and see.
      Nope, 30 milliohms., as in 0.03 ohms
      I have found them at Mouser in times past.
        Yep.
        .030 ohms surface mount
        Search results for: .03 resistor 33 mOhms Current Sense Resistors - SMD – Mouser
          Links to Behringer schematics
          https://music-electronics-forum.com/forum/schematic-requests/42181-links-to-behringer-schematics/page2
          http://bee.mif.pg.gda.pl/ciasteczkowypotwor/%23SM_scena/Behringer/
          It's All Over Now
            PMP1280S
              If it turns out that the mosfet drive ic IXDD404, is (are) bad, it has been replaced by the IXDD604.
                thanks for helpful posts. found 3 blown mosfets, damaged current sensing resistor, open drain leads and shorted dual diode LD20U marked as D20 on print. having trouble locating this dual diode. any suggestion? would anyone
                possibly have one they could spare? thanks again
                  Help us to help you, please.
                  The schematic set has 13 pages.
                  At the top are quadrant nombers and on the side are letters.
                  Please indicate were D20 is.
                    D5LD20U is the part #.
                    https://music-electronics-forum.com/...611#post415611
                      schematic page 11, quadrant 7-A. was able to locate and order a D8LD20U which should work. this is a series connection, tandem polarity diode. thanks again for everyone's suggestions
