Does anybody have the schematics for the Guyatone PS-024 Disortion H pedal? Something in the back end is almost totally shunting my effect signal.
Guyatone PS-024 Distortion H schematics
Here's a link to a clone build document that contains a schematic. It may be exact, or it may be at least similar enough.
https://drive.google.com/file/d/1Vs2...yJIM-HoQm/view"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Test them in place first, pulling and reinstalling them is likely to caause damage. And don't assume you have a bad part. You might, but you might also have a little bit of stray solder bridging two points, or a cracked copper trace.Education is what you're left with after you have forgotten what you have learned.
I've gone over the wiring and the boards quite a bit, don't visually see any issues. I've tested continuity between points, checked for cold solder joints, and did some audio probing. I'm finding various levels of the distorted effect, all seemingly working properly after the pots and sliders, but getting shunted down to incredibly soft at some point. I'll keep digging...
