| | #1 |
| Senior Member Join Date: Jan 2009 Location: Los Angeles
| Vibro Champ filters self-discharging - why?
I am a newbie to amp hacking, so bear with me. I am working on a Vibro Champ, and as I should, I have been careful to discharge the filter caps after the amp has been on for testing etc. However they don't seem to hold a charge - they make no spark, and if I check the first filter node with a VOM after the power is off I only get a reading of like 9 volts. When the amp is powered on, there is plenty of voltage at all the filter nodes and plates. It actually exceeds the voltage on the Fender schematic I have seen, could be because I have a replacement Mercury power trans. So does it sound like the filter caps are bad? - it seems to be the original cap can if I am reading the code #s correctly. Thanks! FWIW the amp seems to work right, but it does sound mushy. I assumed that this was due to it being a 6 watt amp. |
| | #2 |
SO connect yiour meter while it is powered and flip off hte switch. You can watch how quickly it discharges on your mater. Caps can carry a charge a long time by themselves, but in a circuit, they often discharge fairly quickly.
| | #3 |
| Senior Member Join Date: Jul 2007 Location: Indianapolis
Yeah - there's no standby on these little guys, so they get sucked down pretty quickly. If you want to try it, remove the 6V6 and 12AX7(s) (leave the rectifier) and watch the meter as you turn the thing off. BTW - a screwdriver across the caps is a good way to: 1) blow the tip right off the driver 2) blow up what had been a perfectly good cap Use a 220k or so resistor with insulated leads and insulated alligator clips as a bleeder ... until you wire one in permanently. Hope this helps! |
| | #4 |
Should I add a 220K or thereabouts resistor in parallel to the first filter cap as a bleeder then on my amps? What sort of wattage would be indicated? 400v / 220,000 ohms = 1ma x 400v = 0.7 watts, so a 2 watt looks like it would be adequate. |
| | #5 |
A bleeder sure wouldn't hurt and, 2W should be plenty. (you can do the power calculation as (V^2)/R if you want to skip a step) Higher bleeder values are just as safe - they just take a proportionally longer time to drain off the charge, with the very slight advantage of a lower static current drain/power dissipation. Just check that the filter is under 24VDC before reaching in. Hope this helps! |
| | #6 |
Well then what about a 500k 1 or 2 watt?
| | #7 |
Should do fine. (400V^2)/500000ohm = 320mW |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| SF Vibro Champ fuzz | rokplo | Maintenance, Troubleshooting & Repair | 21 | 12-18-2008 09:16 PM |
| Need help on an AA764 Vibro Champ | StratTone | Maintenance, Troubleshooting & Repair | 2 | 11-20-2008 04:56 PM |
| BF Vibro Champ mod | tele-tubby | Mods & Tweeks | 8 | 08-29-2008 12:33 PM |
| Vibro-Champ Help | Rick1114 | Maintenance, Troubleshooting & Repair | 16 | 06-19-2008 02:56 PM |
| SF Vibro Champ Ex Cond | tuberattler | Flea Market | 0 | 06-16-2006 05:05 AM |
