| | #1 |
| Member Join Date: Apr 2007 Location: Texas
| Real Reissue KT66's
I'm getting so tired of reading the hyped puke manufacturers and distributors write about their tubes. Does anyone know if any of the current-stock KT66's out there are truly based on the original Genalex design, and not just a repackaged 6L6? I'm assuming any tube that has the amazing ability to be 100% compatible in any 6L6 amp with a draw of 0.9ma is just a rebottled 6L6. I'm also open to any completely subjective opinions about these tubes...as long as it's not the manufacturer's blurbs being regurgitated Tim |
| | #2 |
| Senior Member Join Date: Oct 2007 Location: Tucson, AZ
...short answer is "no," just some are LESS far from the original specs than others.
__________________ ...and the Devil said: "...yes, but it's a DRY heat!" Last edited by Old Tele man; 11-11-2007 at 02:08 AM. |
| | #3 |
As Old Tele Man infers, it's probably a bit optimistic to expect any tube made in a different factory, in a different country, decades after the original to sound EXACTLY like the "real" thing. But AFAIK it is only the new Sovtek/New Sensor/Tung Sol KT66 (6L6 in a big bottle) that claims to be a "drop in" replacement, the JJ, TAD & Harma/GTKT66HP (Reflector) all draw 1.3A of heater current. I've had good experiences with the Harma/GTKT66HP (they sound like a KT66, rather than a 6L6 - smooth, round, relaxed hi end). I have a JJ KT66 in my Champ at the minute, but as availability is intermittent (round here at least) for the GT/Harma, I haven't had the chance to compare directly. I am not rich enough to compare directly with a GEC but check out the Watford Valves 6L6 test report from 2005. |
| | #4 |
| Old Timer Join Date: May 2006 Location: NYC
I have a set of original GEC KT66's in one of my amps,and have compared the Sovtek and Tung-Sol's and they dont come close.
| | #5 |
Thanks for the replies guys. I did a little more research on my own. Of course there are no real KT66's being produced any more, but I had a short exchange from Doug at Doug's tubes, and it seems the Chinese tubes are probably the closest current-production thing out there. I've heard the GT's are pretty good too. Doug also has some Russians out of the Saratov plant that are supposed to be darn close. I think pretty much everything else out there is a 6L6. I think the JJ's are probably closer to a 6L6. |
| | #6 |
The GT and Harma tubes are from the Saratov (Reflector) factory in Russia. This is the same factory that makes the Sovtek/Tung Sol KT66, but the GTHP & Harma are only availble via GT & Watford Valves. The JJ is relatively new. If the GTHP/Harma sounds "pretty darn close" and the Chinese tube is "closest current production" why isn't it "real"? I doubt that it would be identical wherever it was made. Undoubtedly the GECs are the thing to have but NOS prices are not realistic for your average musician. |
| | #7 |
Yeah Doug has some GEC's for sale too. At $100 a pop and four sockets to fill, I think I'll go with the copies.
| | #8 |
And the ones Doug has are used.Imagine finding 4 that are matched.I got lucky and found a NOS pair of GEC's at a flea market for $100-I'm sure it'll be the last pair that amp sees.They are way out of control,$400+ a pair,and I've seen people pay $300 for a single on ebay.
| | #9 |
| Member Join Date: Jun 2006
I'm runnin' a pair of those chinese {shuguang} ones in a Low Power Tweed Twin. They sound and look nice. JJ |
| | #10 |
| Member Join Date: Jul 2006
| Ratings?
I'm running a pair of Shuguang KT66's in a JTM45 I built for a customer and we're getting 500vdc on the high side of a low-high switchable B+ arrangement and I'm a little nervous about these tubes even though I have 1K screen resistors right off the rail. The original had a 1K common resistor and a 470R for each screen. Does anyone know the plate and screen voltage ratings for these babies? |
| | #11 |
These tubes are 25w tubes. They won't take what a modern 6L6 (30w) tube will take. I'm running them in cathode bias at 400v/40ma. JJ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| How can you tell if it's real PE or fake | Dr. Guitar | Pickup Makers | 12 | 11-06-2007 05:57 PM |
| My magnetometer. Possibly a real obvious question. | Dr. Guitar | Pickup Makers | 2 | 09-18-2007 11:51 AM |
| 5f4 w/kt66's? | scole | Tweed Builders | 1 | 10-27-2006 09:15 AM |
| Anyone subbed KT66's in a BF Bassman? | steel1953 | Mods & Tweeks | 2 | 10-26-2006 04:39 PM |
| jmp superbass kt66's substitution | lil bubba | Mods & Tweeks | 0 | 08-22-2006 10:50 PM |
