Originally posted by thelonious_crunk
View Post
Pre-war amp, not sure of make
Originally posted by mozz View PostCould you post the tube lineup? I have Rider's PA manual and it's probably in there if you find any name on it.
https://worldradiohistory.com/Rider-Manual.htm
Rider's Perpetual Troubleshooter's Manual - 1930 to 1952 - Complete Collection
1)
http://prewaramps.org/
http://prewaramps.org/schematics.htm
2)
http://highgate.comm.sfu.ca/oldradio/index.html
Rider's Radio Service Manuals In PDF Format
It's All Over Now
If the 5z3 (like a 5u4)is original, i'm guessing the output tubes are a pair of 6l6. That is, if the tube with no numbers next to the rectifier is a octal. Someone swapped a metal 6l6 or a glass tube. Looking closer, the unknown tube is almost touching the speaker, so chances are it was a metal 6l6 also. Now, if the rectifier was metal, it would be a 5z4, which would be equivalent to a 5y3. So you really don't see 5y3's with push pull 6l6's, but yet there are a few in the PA book like that . I'm guessing they didn't put out all that many watts so current was under the 5y3 limit, which is 100-125ma. I'm sticking with 5z3, 6l6, 6l6, and pre amp tubes. Could be a Masco with that many inputs, also listed under Mark Simpson Co, (MASCO).
Here is "The book" for prewar PA amps, phonos and other things. You can get this on cd (which i also have) for $10 but i wanted the hard copy, not easy to find.
Originally posted by mozz View PostIf the 5z3 (like a 5u4)is original, i'm guessing the output tubes are a pair of 6l6. That is, if the tube with no numbers next to the rectifier is a octal. Someone swapped a metal 6l6 or a glass tube. Looking closer, the unknown tube is almost touching the speaker, so chances are it was a metal 6l6 also. Now, if the rectifier was metal, it would be a 5z4, which would be equivalent to a 5y3. So you really don't see 5y3's with push pull 6l6's, but yet there are a few in the PA book like that . I'm guessing they didn't put out all that many watts so current was under the 5y3 limit, which is 100-125ma. I'm sticking with 5z3, 6l6, 6l6, and pre amp tubes. Could be a Masco with that many inputs, also listed under Mark Simpson Co, (MASCO).
Originally posted by thelonious_crunk View Post9 tubes total, one 5Z3 coke bottle no tint, one 6L6 is glass black tinted. Smaller metallic: one 6C5, five 6SF5. And then the 2nd coke bottle unknown believed to be 6L6
http://tdsl.duncanamps.com/show.php?des=6C5
http://tdsl.duncanamps.com/show.php?des=6L6
http://tdsl.duncanamps.com/show.php?des=5Z3
It's All Over Now
What is written on the metal can tube?
If you only have one 6L6, it might be a single ended amp. Seems the OT is mounted to the speaker. See how many primary wires/terminals it has. Two means single ended, PP requires three. Secondary terminals connecting to speaker.Last edited by Helmholtz; 03-16-2021, 06:17 PM.- Own Opinions Only -
