Originally posted by glebert
View Post
Pre-war amp, not sure of make
There are 3 of what appear to be identical cathode bias resistors. Two of them read 250 ohms, while one reads 230 ohms and leads to a 6SF5. Not sure if that one has begun to bite the dust.
Also looking for modern replacements for the large bias resistors, 200ohms "C 10 F", utah 3000 ohms, and an Ohmite Brown Devil 20000 ohms. Are these just like standard small resistors now?
But yeah...appreciate all your help so far. I'm pretty novice to working on amps. I am gonna carefully rewire it, recap, and reflow any cold joints since they are all oxidized. Also make fresh new spots for the grounds to the chassis. Just waiting for parts to arrive and will keep updated.
Originally posted by thelonious_crunk View PostThere are 3 of what appear to be identical cathode bias resistors. Two of them read 250 ohms, while one reads 230 ohms and leads to a 6SF5. Not sure if that one has begun to bite the dust.
Larger sized resistors mean they have/require a higher power rating.
First targets should be to draw a schematic, get the amp working and do some measurements.Last edited by Helmholtz; 03-17-2021, 09:59 PM.- Own Opinions Only -
- Likes 1
"Power transformer putting out around 39 ohms"
I'm taking that as you measured the resistance of the primary and it's 39 ohms. You need to measure the secondary too, it should be a few hundred ohms. Probably have to disconnect a wire because of components attached to it. I would also measure the filament wires as if a tube is not lighting up that may be a major problem. That will be less than 1 ohm usually. I'm saying it's a field coil speaker because they often use the octal plug just like this and run up to the speaker/field coil assembly.
Originally posted by mozz View PostI'm saying it's a field coil speaker because they often use the octal plug just like this and run up to the speaker/field coil assembly.
Certainly not a field coil, which needs to be in place of the speaker magnet.
I don't see a need to measure PT winding DCRs at this point. Just pull the rectifier and measure PT secondary voltages.Last edited by Helmholtz; 03-17-2021, 10:54 PM.- Own Opinions Only -
- Likes 1
Aside from the PT, I don't see a second transformer as part of the chassis, so I was thinking the transformer mounted to the speaker must be the OT."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 2
Originally posted by The Dude View PostAside from the PT, I don't see a second transformer as part of the chassis, so I was thinking the transformer mounted to the speaker must be the OT.
So what do you think is the small transformer mounted to the speaker frame, where the 3 wires connect to?
- Likes 2
Originally posted by glebert View Post
I am not saying that it is a field coil speaker, but the Rola shown on this page (http://djcarlst.provide.net/FieldCoi.htm) looks a bit like the OPs to me.
But it's easy to find out if the speaker carries a permanent magnet or a coil: See if it attracts a screwdriver.
- Likes 1
My question would be: If it's not the OT, then where is the OT? I don't see a 3rd transformer in the amp. At any rate, it should be simple enough to figure out by simply looking at how it's wired."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostMy question would be: If it's not the OT, then where is the OT? I don't see a 3rd transformer in the amp. At any rate, it should be simple enough to figure out by simply looking at how it's wired.- Own Opinions Only -
- Likes 2
Testing of an unknown transformer
It is enough that the two near turns are in mutual short-circuited, the DC primary resistance will be 39 ohms, but the transformer will be hot and the primary fuse will be blow.
The transformer is tested "upside down" by applying 6.3V from another transformer, to 6.3V connector transformer under test (TUT) and measure the voltages at his connections.
If the bulb light, it is a sign that the TUT has turns in mutual short-circuited.
Attention
On transformer under test, dangerous voltages appear.
It's All Over Now
- Likes 1
Yes, looks similar indeed. But seems to use more than 3 wires. With only 3 wires the field coil would have to be in series with the CT, what would cause a lot of sag.
But it's easy to find out if the speaker carries a permanent magnet or a coil: See if it attracts a screwdriver.Last edited by thelonious_crunk; 03-18-2021, 04:17 AM.
