Originally posted by Helmholtz
View Post
Pre-war amp, not sure of make
Originally posted by thelonious_crunk View PostSo I managed to get it working first try, i did 19 caps in 3 hours and used my variac to slowly bring her to life. This was pretty straight forward. Its great and fairly quiet from any noise. Definitely sounds good. All 4 inputs work. Will be looking for the matched tube set soon. Oh, and no shocks, just a small soldering burn on my middle finger
Thanks for helping me
- Likes 2
Originally posted by glebert View Post
Wow, that is like winning the lottery that it worked after just cap replacement. Seems like you did a good job on replacing them if it works so well.
- Likes 1
Originally posted by Helmholtz View PostVK, you're really eagle-eyed and alert .
So the OP seems to be wrong (or I misinterpreted) about only 3 wires between amp and speaker.
About Field Coil Loudspeakers
http://djcarlst.provide.net/FieldCoi.htm
https://antiqueradios.com/forums/viewtopic.php?t=158496
Field Coil Speakers....
https://ampgarage.com/forum/viewtopic.php?f=11&t=26686
Field Coil Speakers?
https://www.google.com/search?q=rola+site%3Ahttps%3A%2F%2Fwww.kevinchant.com%2F
https://nzvrshome.files.wordpress.com/2018/12/Rola-Catalogue-c1948.pdf
https://patents.google.com/patent/US2770681
Loud-speaker
https://www.google.com/search?q=Field+coil+speaker
It's All Over Now
Well i see 3 terminals on the speaker, unless one is ground. The speaker connector going from the amp is 4-prong. Either way, you guys helped me stay on the right track with this- Own Opinions Only -
- Likes 1
No doubt it is a 4-prong/4-pin plug, but the question is: How many wires are actually connecting to the plug?
Please photo your speaker transformer both sides.
The speaker connector is on the bottom of the OT, on the top you see 3 wires of the OT (a1 / + HV / a2) and 1 wire of the field coil.
The other wire of the field coil is connected to the middle terminal of the OT.
On the speaker terminal you have 4 wire (see lay post # 76 and photo #78)It's All Over Now
- Likes 1
Possible one side of the OT secondary is soldered direct to the speaker frame, and one side of the voice coil is also.Education is what you're left with after you have forgotten what you have learned.
- Likes 2
Originally posted by thelonious_crunk View PostI'm gonna send vintagekiki pics of it when i get home via email since my pics are too large from my phone on here
Thank you
1)
2)
Perfect
Pure natural antique clean sound, I haven't heard in a long time.It's All Over Now
- Likes 1
