That looks a lot better with 2 matching speakers. That squarish speaker you took out seems a bit familiar, maybe a studio monitor, but can't be sure.
GK 250ML Speakers
Probably.
AFAIK original ones were made by Pyle (which also suppied those in the 4 x 10" cabinets), but of course any day of the week they can switch to Eminence.
Any codes printed on those speaker frames?Juan Manuel Fahey
I have one, but you'll have to buy the whole amp that it's in.
Seriously though, Mouser has a host of Molex connectors. If you get out your calipers and do some measuring, you can probably find a connector that will work. Then, it's just a matter of adding the wiring."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
Originally posted by sweatyk View Post
says:
1056 Fisher Speakers 1059 Channel Speakers 1098 Pyle Speakers 1113 Acoustic Fiber Sound Speakers 1149 Curtis Mathes Speakers 1191 Micro Magnet Speakers Juan Manuel Fahey
- Likes 1
Searching for various combinations of the squarish speaker brought this.
Quite close, only it´s Panasonic Japanese.
That said, that speaker might have been used in a "USA model/specs" Cabinet (Hi Fi? / Studio monitor?) , I have seen power transformers labelled US - USA - EU - AU - UK and that means specs or Electrical Safety approval, or intended market, not necessarily Country of Origin or Manufacture.
Also a US made speaker , specially from the 80´s, "should" show an EIA code, this one does not.
An extra detail: **magnet backplate** IS Asian.
Traditional speaker makers (US - EU - even my own) cut/stamp backplate from a thick cold rolled steel sheet, punch a hole in it, lathe turn the polepiece out of a cold rolled steel bar and join both together by various mechanical methods, sometimes pressing (with a huge hydraulical press) polepiece into a same diameter hole (say 1.5" as in those Pyle speakers) , often "nailing" them together by hitting them with a pointed hard steel tool so they expand a little and can´t move any more, similar to primer crimping in MilSpec ammo , both techniques clearly seen here, while Asians forge the whole shebang out of a large ball of molten steel, so "no joints".
Also edges look rounded like pressed dough (what they are,only it´s steel dough); traditional manufacturing shows ragged punched edges or , best case, same but turned smooth in more expensive speakers.
Makes easy to tell UK vs China Celestion,by the way.
- Likes 1
Originally posted by The Dude View PostI have one, but you'll have to buy the whole amp that it's in.
what term would you use when searching for this? I've put in female pin socket, molex but can't seem to find one like this. I know it has to be out there. Anyone care to help a brother out?
Here's a start. You'll have to measure some things and update the search to see if they have what you need.
https://www.mouser.com/Molex/Connect...yvsm2dZ1ytkls2
The white connector is an insulation displacement connector or IDC. The IDC has special pins with little sharp edged slots in them. A special press is used to shove the insulated wire down into the slot, and contact is made. You won't have such a press. SO when I encounter this I use connectors from the same series but that use crimp-on pins that are then slipped into the plastic housing. That connector is in the Molex KK-156 series. You need a four slot housing. (Secret tip: if you can only find a ten space, you can cut off a few spaces from the end...instant four.) You will need a crimper, and while there are wonderful expensive ones, my cheap Waldom one has worked just fine for me for decades.
Like this one:
https://www.digikey.com/en/products/...iABEgIJ1fD_BwE
Mouser and I am sure others sell the individual stuff, but they also sell small kits, which include a housing or two and a handful of crimp pins
Here is a four slot kit from Mouser. I am sure other Molex dealers also sell such kits.
https://www.mouser.com/ProductDetail...GkST%252BII%3DEducation is what you're left with after you have forgotten what you have learned.
- Likes 1
Correct me if I'm wrong on the speaker connection. The yellow and red wire connect to the - side of the speakers and the brown and orange connect to the +.......or do I have that backwards? On the schematic it has the red and yellow going to a .33 ohm resistor to ground (R127 & R133).
Originally posted by Enzo View PostThe white connector is an insulation displacement connector or IDC. The IDC has special pins with little sharp edged slots in them. A special press is used to shove the insulated wire down into the slot, and contact is made. You won't have such a press. SO when I encounter this I use connectors from the same series but that use crimp-on pins that are then slipped into the plastic housing. That connector is in the Molex KK-156 series. You need a four slot housing. (Secret tip: if you can only find a ten space, you can cut off a few spaces from the end...instant four.) You will need a crimper, and while there are wonderful expensive ones, my cheap Waldom one has worked just fine for me for decades.
Like this one:
