Originally posted by ca7922303
View Post
EL34 Grid Stopper resistor
This topic is closed.
[QUOTE=ca7922303;n954534]Originally posted by catalin gramada View PostDo you have a capacitor at hand, say 22-100n or so?[/QUOTE
I have a few 10uF 50v on hand."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
[QUOTE=catalin gramada;n954536]Originally posted by ca7922303 View Post
No need it just a short wire from red marking to one of the solder point above GND mark
[QUOTE=ca7922303;n954551]Originally posted by catalin gramada View Post
With jumper wire connected and V6 in or out, there is no red plating, but also no output with V6 installed and jumper wire connected."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
