Tweeter reads (3.9 ohms) resistance, no treble.
JBL EON 515XT No Treble
Originally posted by The Dude View PostThere can be driver faults other than an open voice coil.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
The HF driver on these is a 2414H 1" compression driver, so not a piezo. But yes, it could have a shifted gap, diaphragm/coil separation, etc. In other words, just because the coil measures 3.9 ohms does not mean the driver works. It's best to see if it actually makes sound. Also, the driver should be measured out of circuit to make sure a crossover coil or parallel resistor isn't being measured."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
Could be a blown protection bulb.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
- Likes 1
It's a HF driver. Of course, it's not going to be as loud as a 15" speaker running full range music through it. And don't try to get it louder with a full range source. It's not meant to do that. You only need to know that it works."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by nosaj View PostDid you see any fuses on the crossover?
nosaj"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
I'll add: The 2414H is an 8 ohm driver, so I'd expect the DCR to be around 6-7 ohms instead of your 3.9. It's possible you have shorted coil windings. I'd try another driver to see if it works. You don't need the exact driver. You can just clip lead something external for testing. Any known good tweeter/horn driver will work as a test.
Last edited by The Dude; 01-05-2023, 04:33 AM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
