Does increacing the relief usually mean -more- fret buzz? I can never work it out even imagining vibrating strings like a skipping rope.
My HM fender- poorly.
Originally posted by Sea Chief View PostDoes increacing the relief usually mean -more- fret buzz?
A relief of 1mm looks way too much. As recommended above, use an e-string as a feeler gauge.
- Likes 2
Higher relief increases action wihout reducing string buzz. Buzz only reduces with increasing bridge height. For lowest no-buzz action you want just above zero relief.
1mm is the least ammount of relief I've ever done, or really able to even measure! too -much-? do you mean "too little" IE I need to increase 1mm to say 2mm?
Hi Helmholtz.. 1mm is too much?? crikey I'm all at sea here then/ thought I knew all this but obviously not.
1mm is the least ammount of relief I've ever done, or really able to even measure! too -much-? do you mean "too little" IE I need to increase 1mm to say 2mm?- Own Opinions Only -
I'm speaking of 0.2 to 0.25mm max. Anything more just increases necessary no-buzz action.
Really?? sorry anything more does what.. basically increaces buzz? (I dont quite understand what "increaces neccessary no-buzz action" means.. my head starts to explode).
Please try my proposals, I'm getting tired of repeating myself.- Own Opinions Only -
- Likes 1
Relief just adds action, but for no good. Raising string height at the bridge increases action but also reduces string buzz.
I do not like doing a suggestion without picturing why its to be done.I prefer to understand 1st.. then AHA! & doing it.
Increacing 'action'-? does this mean increacing the strings "area" to vibrate perhaps? I can only try & guess you see.
I also do not not understand what you are meaning by 'action'.
Most players prefer lowest possible action without string buzz and that's only possible with minimum relief.Last edited by Helmholtz; 10-19-2020, 07:14 PM.- Own Opinions Only -
If you mean "decreasing" as lowering, yes. Less relief gives lower action.
I have a feeling a bit of lost in translation here, but now not important: now I understand you.
A Q tho. How can I possibly measure such small heights as 0.2mm or 0.25mm? I know you germans are given minute feeler-guages in your xmas stockings fro m age 4 onwards, but us engrish pigs.. we only have bits of paper & leaves).
(but how can decreacing not mean anything other than lowering-??!! can you see my point??).
Treble e-string diameters:
0.008" = 0.2mm
0.009" = 0.23mm
0.010" = 0.25mmLast edited by Helmholtz; 10-19-2020, 07:56 PM.- Own Opinions Only -
Because I (as well as my dictionary) don't know what "decreace" means, I only know decrease as to lower or reduce.
With a piece of treble e-string as said several times. That's what I use, works much better than flat feeler gauge.
0.008" = 0.2mm
0.009" = 0.23mm
0.010" = 0.25mm
Alot lost in translation, but, we are on the same page with decreace and increace (I think maybe increacing the action = decreacing the relief.. hence our miscommunication.. or maybe not, but it doesn't matter for now).
Trouble for me is the nut is body-end, so will take a day or so to dial in 0.23 neck relief, taking strings off/ on/ off etc. A total bitch.
(You are still misspelling decrease and increase.)
You will need to tighten (turn clockwise) the truss rod nut. Start with a quarter turn only and check again.
Body-side nut is a PITA - not only for you.Last edited by Helmholtz; 10-19-2020, 09:27 PM.- Own Opinions Only -
- Likes 1
