Originally posted by Sea Chief
View Post
My HM fender- poorly.
Originally posted by Sea Chief View Post
or, do you just like a high action?
As said, around 2mm action is typical with many pro strat players. Depending on playing style some get away with somewhat lower values. You need to find out yourself.
Fender Strat manual recommends/specifies treble 2 (+/-0.4)mm, bass 2.4 (+/-0.4)mm measured at fret17.
- Likes 1
Haha! No, I don't prefer high action. But clear ringing is more important to me than low action.
I don't think you could have changed PU to string distance by more than maybe 1.5 mm by raising the action.
Rather it seems that neck and body don't match well and this neck would require a deeper neck pocket in the body.- Own Opinions Only -
Originally posted by Helmholtz View PostI don't think you could have changed PU to string distance by more than maybe 1.5 mm by raising the action.
Originally posted by Helmholtz View PostDifferent manufacturers use different dimensions. I've often seen this problem.
E.g. my Fender Japan strat neck doesn't fit any of my Fender Mex or USA Strat bodies.
Excessive distance between strings and pickguard means that your fretboard lies too high above the body and must have one of the following reasons:
- too shallow neck pocket (for given neck)
- too thick neck "tongue" (for the body)
- slanted contact faces between neck tongue and neck pocket (less likely but does happen, effect is the same as with an inner/back end neck shim).
None of these conditions will look bad.Last edited by Helmholtz; 10-21-2020, 08:29 PM.- Own Opinions Only -
I can't say this doesn't fit.. it did fit the pocket perfectly & looks spot on to be honest (the only difference being a slightly larger headstock afaict). Its just now Ive done this raising saddles thing Ive got alot of air below strings now.
- Likes 2
Originally posted by Dave H View Post
The last partscaster I put together using parts from different sources ended up having the action far too high with the bridge saddles set to the normal height. I had to put a shim (a few thicknesses of business card) in the neck pocket at the neck pu end of the pocket to lower the action. If yours doesn't have a shim there you could remove perhaps it would benefit from a shim at the other (outer) end of the pocket? This would tilt the neck forwards raising the action so the saddles could be lowered to restore normal 2mm action.
Originally posted by Helmholtz View PostI'm not sure if I understand correctly, but a typical neck shim at the end of the pocket (neck PU side) will force an even higher saddle height.Last edited by Dave H; 10-21-2020, 09:04 PM.
- Likes 1
Bugger. I was measuring not at the 17th.. but the 12th fret. Im used to doing the 12th, no idea why.. prolly cos those two dots drew me in like little eyes..
Now Ive got 2.2mm on the low E, and nearly 3mm on the top E.
