Originally posted by Jim Darr
View Post
I've got a cnc winder and even it has its little quirks and you have to keep an eye on it. How the bobbins are fitted differing wire gauges tension etc. I still use a cobbled up lathe with speed controller and wind by hand for my single coils. The benefit of hand winding is tension control and instant wobble adjustment although tpl is probably all over the place. As for modern cnc guitar production the cutting is by and large accurate, although look closely at the inlay reccesses on chinese guitar, also cnc is not going to make a crappy piece of wood that hasn't been properly seasoned into a decent guitar. As I have been repairing and setting up guitar new and old for the last 40 years I don't really see any great improvements in guitars as the base materials seem to be getting worse. I should be retired in 5 years or so and am curious to see what kind of garbage the major guitar factories will be producing to keep profits high and costs low. This might be a good time for all the small time makers out there to step in. The only problem is most guitarists these days wouldn't know the difference between a piece of chipboard (particle board I think it's called in the USA, ) and a piece of rosewood. When I started all those years ago the guys were talking about growth rings per inch quarter or slab sawn wood and were generally in the know. This was all without the internet. Now we have the internet, hundreds know what rosewood is, they've seen it on a screen or read about it from someone else that either has never seen it or seen it on the screen so on ad infinitum. Just watch out when that drone delivers your new cnc winder through the glass window as no one programmed it to check if it was open !!
Cheers
Andrew
