Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
View Poll Results: Is the digit to the right of the hyphen the letter "Z" or the number "2"
Z 3 75.00%
2 1 25.00%
Voters: 4. You may not vote on this poll
Old 11-23-2008, 05:15 PM   #1
National/Valco serial number help
Call me anal, but here goes...
I'm just about finished with my National Model 90 refurb but I'm stuck on one detail... the serial number sticker. Like a bonehead I didn't write down the number or save the sticker before I ran the vacuum over the chassis and naturally the vacuum destroyed the sticker. But I do have a pre-vacuuming photo so I want to make a reproduction to stick on the back of my chassis. But here's the thing... the photo was at a weird angle and the sticker was curled a bit, so I'm having trouble with one digit... it is either 2-Z8642 or a 2-28642. Is it a Z or a 2? Does anyone know whether these serial numbers were all numbers or did they include letters (Z)? Pic is attached. I'm leaning towards 2. Thanks! Dave
Valveboy is offline   Reply With Quote
Old 11-23-2008, 05:45 PM   #2
How about none of the above? It looks like that number was printed using a rubber stamp, maybe of the kind that had bands of numbers which were indexed to create the sequence. The horizontal line at the bottom of those two characters that look like 2's or Z's could be an artifact from the stamp, and they are in fact 7's... so maybe 2-78642 or even 2-78647? Zooming it in really big on my screen I'd lean toward 2-78642. The shape of the last character looks similar to the leading 2.
MPM
martin manning is offline   Reply With Quote
Old 11-26-2008, 10:49 PM   #3
Not sure about that vintage, but Valco used letters like X,V etc in their serial numbers. I think there is a Z after the dash, and it makes sense. There is a listing of Valco serials by year, and you may have to google to find it, or go on the Steel Guitar Forum and ask.
I have an old National amp, and the serial, for example is X309, and two National guitars with the same type numbers.
pila is offline   Reply With Quote
Old 11-30-2008, 05:07 AM   #4
defaced's Avatar
I say it's a "Z". The line weight use for the two "2"s in the picture are completely different than the character in question.
__________________
-Mike
defaced is offline   Reply With Quote
Old 12-13-2008, 03:21 AM   #5
Seeing the serial number list for National/Valco, I didn't find a prefix with a "Z" in it. Hard to say what that's all about.
Old 12-14-2008, 02:29 AM   #6
You have to remember these were the last sad days of Valco. I've seen a couple different foil sticker serial number styles from this time period. The first digit is a 2 and the rest *should* be numbers as well. I haven't seen any serial stickers myself that have letters after the prefix. the 2 prefix is early to mid 1968 based on my reference matls. I'd guess the mystery digits are 7's
Sweetfinger is offline   Reply With Quote
Old 12-14-2008, 02:34 AM   #7
Yes , those were sad days I think. It was Fender mania after that
Old 01-14-2009, 09:50 AM   #8
txstrat's Avatar
I'm convinced it's the number 2.
Because the sticker is curled, the "curve" on top of the number "2" can't be seen due to the curl and only makes it look like a Z.
Print out a "2" on a blanc sheet of paper and bend the top towards yourself (just like looking down on the cutting edge of the paper), you'll notice the bow will disappear and look like a straight line. Hence makes it look like a "Z".
For reference take the number "8" right next to the "2". You can't see the upper "circle" of the "8" because of the same reason.
txstrat is offline   Reply With Quote
Old 01-14-2009, 08:30 PM   #9
So, if it's a 2, it's one of Valco's last productions, according to the list.
AMP FENDER BLUES DELUXE serial number Guitarreroviejo Guitar Amps 2 08-05-2008 04:31 PM
Valco/National/Airline fake humbuckers? Possum Pickup Makers 16 03-31-2008 12:56 AM
Non-S.O.I.C. Serial Flash? kingsteven Music Electronics 5 09-24-2007 12:48 PM
Free '61 Valco X-former for rewind Sweetfinger Repair and Restoration 0 06-08-2007 10:43 AM
Valco pickup specs? rocket Pickup Makers 10 04-20-2007 06:55 PM
