Old 12-03-2008, 10:57 PM   #1
peavy problems
my peavy recently took a short (maybe 6") fall and it compleatly stoped working. as it being a solid state i figured it would just take the beating but when i plugged it in later that night it didnt wokr at all, so i figured maybe the fuse was blown, so i replaced the fuse. i then plugged my amp in again and heard that famillier hum, but in less then a second a very loud crack/buzz came balreing out of the amp. my friend eric says the power supply could be loose as was the problem with his peavy of the same model (larger wattage) can someone tell me what's wrong with my amp?
ibanez_RG350DX is offline   Reply With Quote
Old 12-04-2008, 04:11 AM   #2
No one will know until they look inside. It fell, something was knocked loose. COuld be a wire came off, or a whole connector full of wires. A nut or screw might have come loose and found its way under a circuit board, shorting things out. A component may have broken off the board and is swinging around. Whole circuit boards could break free and be flopping around touching who knows what.
Really, someone has to look inside and see what's up. As to what electrical damage has now been done, a tech can determine that.
__________________
Old 12-04-2008, 11:38 AM   #3
i did look inside the amp, nothing seems to be loose but i will check again, thanks
Old 12-05-2008, 02:33 AM   #4
Well, by "looking inside" I include doing electrical checks.
__________________
Old 12-14-2008, 09:58 AM   #5
kor
If it has a PC board, it could be cracked between solder connections. I've seen it before. Just my tw0 cents!
kor is offline   Reply With Quote
Tags
40 watt, amp, fall, peavy, solid state
peavy 5150 combo chris78 Maintenance, Troubleshooting & Repair 2 10-07-2009 06:47 AM
Need Female XLR part for Peavy Unity Mixer galphir Music Electronics 1 11-12-2008 07:47 PM
Problems with Crybaby Slowhand0461 Guitar Effects 2 10-25-2007 06:09 PM
peavy classic 30 popping noise vanwaltly87 Maintenance, Troubleshooting & Repair 6 07-13-2007 08:14 PM
Crybaby problems gerry Guitar Effects 5 03-15-2007 05:50 PM
