Results 1 to 4 of 4
Thread: Sunn SX8350 Powered Mixer
    Dec 2008
    2
    Hi guys, hope someone can help me. I've got an old Sunn SX8350 powered mixer that's been working fine for the past couple years that I've had it. Suddenly, it started having an issue: I can be playing through it just fine, and out of nowhere the volume will either fade out or the sound will just quit. Sometimes it comes back on when I turn the switch off-then-on, sometimes not. If I happen to be playing a guitar through it, I can unplug the guitar, and when the speakers "pop" it brings the volume back up. Anybody smarter than me have any thoughts about this? I'd appreciate any input. Thanks.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,025
    Check the cutout contacts on the patch jacks. On the front, the various jacks like power amp in and graphic in and so on.
    Dec 2008
    2
    Enzo-
    Thanks for the advice. When the amp cut out the next time, I plugged a cord into the "Main Out" jack- nothing. Then I plugged into the "Monitor Out" jack- BAM! the amp came on, and it never went out again during the next 30 minutes that I played through it. So what is it, just crap built up on the terminals that needs to be knocked off every once in a while? Thanks for your help.
    Old Timer Gtr_tech's Avatar
    Nov 2007
    Owosso, Mi
    1,537
    The jack contacts oxidize, get dirty, crack loose from the board, etc. Clean them first then check solder if its still intermittant.
  1. yamaha emx 660 powered mixer help
    By dtobian in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-25-2010, 01:50 AM
  2. Mirage powered mixer
    By marx in forum Music Electronics
    Last Post: 08-06-2008, 02:08 AM
  3. Yamaha Powered Mixer Emx 860st
    By e_c_mccollum in forum Music Electronics
    Last Post: 04-18-2007, 11:02 AM
  4. high powered PA amps.
    By Mars Amp Repair in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-27-2007, 01:13 AM
  5. Noise when standby on or powered off
    By Thorny in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2006, 05:52 AM
