Old 12-14-2008, 08:13 PM   #1
Delta Blues Not Switching
My DB switches when switching with the channel button but when I plug in a 5150 footswitch it goes to the clean channel and wont switch. I figure the footpedal is wrong but my question is this. As long as it switches manually when i get the right footpedal it should work, correct?
chunkitup is offline   Reply With Quote
Old 12-14-2008, 11:37 PM   #2
The footswitch isn't complicated - 2 stomp switches wired to a stereo (also called TRS) 1/4" plug. Each switch connects either TIP (Tremolo) or RING (channel) to SLEEVE (gnd).
The right footswitch should still work if channel switching works at all. You could make your own, too.
Don Moose is offline   Reply With Quote
Old 12-15-2008, 04:50 AM   #3
Does your 5150 FS have LEDs and stuff? Like if the LED was in series with the relay it might not be able to pull it in?
__________________
Old 12-15-2008, 04:04 PM   #4
The 5150 fs does have led's. I just got a vox 2 switch pedal that does not have leds and it still doesnt switch. What should I look at first?
Old 12-15-2008, 04:08 PM   #5
The vox pedal is wired exactly as you said Don Moose. Would it matter as far as the channel switch being either tip or ring?
Old 12-15-2008, 04:32 PM   #6
Supporting Member
I know it sounds like a stupid question, but have you got the channel button pressed in when you hook up the footswitch? (As you probably are aware - if it ain't pressed, it overrides the footswitch)
__________________
Old 12-15-2008, 08:22 PM   #7
And here I am kickin myself in the ass. I did not know that and yes the amp switches perfectly now.
Old 12-16-2008, 12:22 AM   #8
It's always the little details.
Enjoy!
Old 12-18-2008, 04:37 AM   #9
been there,done that
pila is offline   Reply With Quote
Peavey Delta Blues pchilson Maintenance, Troubleshooting & Repair 30 01-14-2009 04:44 AM
Peavey Delta Blues buzzing WholeToneMusic Maintenance, Troubleshooting & Repair 12 04-14-2008 09:17 PM
Peavey Delta Blues hum. please help! andrewmay Maintenance, Troubleshooting & Repair 5 07-16-2007 02:06 AM
Peavey Delta Blues pbdog Maintenance, Troubleshooting & Repair 1 05-24-2007 12:52 PM
peavey Delta Blues pbdog Maintenance, Troubleshooting & Repair 4 04-02-2007 07:37 AM
