Old 01-18-2009, 08:26 PM   #1
ugly distortion in twin reverb
The vibrato channel of my twin reverb has an unintential ugly distortion. Espacially on the low notes with the channel volume over 3. (guitar is directly connected to the amp)
Since the normal channel is okay I guess it is not the power output stage.
I swapped all the tubes (no result)
I switched the normal channel and the vibrato channel by switching pin 6 of v1b and v2b (so the normal channel goes through the reverb and vibrato and the vibrato channel not) This time the normal channel distorts.
Reverb and vibrato are turned off (zero)
changed the .022 cap after V2b and the .1 cap after V4b (no results)
At this moment I'm a bit clueless. Where can I look any further.
One thing I noticed was that the voltage on pin 3 and 8 on v4 is a bit low 1.8 V instead of 2.3 V (How can I fix this?
Can somebody help me? You can find the schemantic on:
http://www.ampwares.com/schematics/1...F_Twin_Rev.pdf
Thanks
In advance
Leon
leejon is offline   Reply With Quote
Old 01-18-2009, 09:13 PM   #2
Does removing V3 reduce the distortion?
Re V4 cathode voltage - you can't just look at that in isolation, what are the grid, plate and supply voltages, what happens if a known good tube is put in?
Peter.
pdf64 is online now   Reply With Quote
Old 01-18-2009, 10:36 PM   #3
Hi Peter,
removing v3 does not help.
about the cathode voltage, turns out i was looking at the wrong schematic, its a 135W twin instead of a 100W.
http://www.ampwares.com/schematics/t..._135_schem.pdf
cathode voltage is okay (switching tudes does not give a better result)
thanks for the answer.
Leon
Old 01-18-2009, 11:33 PM   #4
Supporting Member
Alex R's Avatar
sounds like you isolated the problem to V2a and the following tone stack. And you already tried a new tube in V2. So are the V2a voltages in the right area? A little high or low is ok.
Maybe swap the cathode bypass resistor - 25uF/25v.
Not an awful lot else I can think of to cause distortion in there - poor jack contacts? - noisy pots? What does it sound like?
Alex R is offline   Reply With Quote
Old 01-19-2009, 04:17 AM   #5
Leaky cap upsetting the DC levels in the stage?
__________________
Tags
distortion, reverb, twin
SF Twin Reverb Distortion - Filter Caps??? mikeboone Maintenance, Troubleshooting & Repair 27 09-12-2009 06:09 PM
SF DeluxeReverb ugly distortion Zouto Maintenance, Troubleshooting & Repair 18 05-06-2008 01:27 AM
Questions re ~1976 Twin Reverb/trashy distortion Steve S Maintenance, Troubleshooting & Repair 11 03-21-2008 05:38 PM
Funky distortion circuit discussion - fender 'super twin' amp tele_guitarist Theory & Design 4 08-13-2007 06:33 PM
Super Twin distortion? drewl Maintenance, Troubleshooting & Repair 3 07-11-2006 03:22 AM
