Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 11-16-2006, 07:17 PM   #1
ian2113's Avatar
Torres Engineering "Tone Frenzy" - Experience?
Has anybody buillt the "Tone Frenzy" designed by Torres? It is a single-ended, cathode-biased 6L6 design with high-gain pre-amp and reverb. The plans are available for free on the Torres Engineering web site. They also sell a kit that includes all the parts except a chassis and cabinet, and an "economy kit" that leaves out the tubes and some hardware.
See these links:
http://torresengineering.stores.yaho...plantomak.html
http://torresengineering.stores.yaho...tonfrenpa.html
http://torresengineering.stores.yaho...frenecpar.html
I am *seriously* considering building this amp. It would be *nice* to accommodate a choice between 6V6 and 6L6 by making the bias adjustable and using a multi-tap output transformer, but I could live with the design as-is.
If you've built one of these, please post your experiences!
Cheers,
Ian
ian2113 is offline   Reply With Quote
Old 11-17-2006, 04:27 PM   #2
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
I have not built it but I can tell you from my other buidling experiences using extra gain stages in small 8-10 watt SE class A amps, even with the localized NFB loop in the first preamp stage, it still could have mongo gain and be almost unusable gain compared to how easy it will be to overdrive a cathode biased 6V6 and maybe even the 6L6.
Tone Frenzy? Buzz Frenzy might be more like it if not careful.
Plus there are errors in the schematic.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 11-17-2006, 10:35 PM   #3
ian2113's Avatar
Good points, Bruce. I am attracted by the idea of a SE 6V6/6L6 amp *with reverb* but the potential bugaboos of the "high gain" design have kept me from taking the plunge.
My real goal, power-wise, is in the 6V6 range, 4-5 watts, with reverb. I think that what I really need to do is to try grafting a simple reverb circuit onto a simple SE amp design as a breadboard project, work out the kinks, and then build the working model.
Any suggestions would be most welcome!
-Ian
Any
Old 11-26-2006, 09:46 AM   #4
Well then, consider taking a look at a simple black face or silver face Princeton Reverb 1270 and keep in mind the ZERO GAIN cathodyne driver "is" the push pull circuit of the two power tubes. With a SE 6V6/6L6 PA, you don't need it... so the triode in front of the cathodyne driver would RC couple to your SE 6V6/6L6 grid... just like a black face Vibro Champ.
Three preamp tubes and one power tube and rectifier should do it.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Old 11-26-2006, 05:50 PM   #5
ian2113's Avatar
Bruce-
Thanks for pointing out something that should have been obvious to me. All the building blocks are out there... I just have to recognize them and put them together to suit my needs! The breadboarding will commence shortly...
Cheers,
Ian
__________________
Ian E. Abbott
"Some days I make a little progress..."
Mission Amps 5E3
Weber 5C1
Measuring and defining "tone" and stuff Just Bob Pickup Makers 9 10-23-2006 01:34 AM
torres engineering tube rec. kit MitchK Mods & Tweeks 10 10-10-2006 02:07 AM
Standard Amp "body" and "Limit" controls - what the hell are they? Ptron Theory & Design 7 10-02-2006 06:32 PM
Questions about suspect new "Child Media-Monitor" product Brad1 Lobby 6 07-12-2006 08:06 AM
"best" passive balance speaker simulated line-out? Chris / CMW amps Theory & Design 4 06-21-2006 04:52 PM
