| | #1 |
| Senior Member Join Date: Jul 2007 Location: leighton buzzard, uk
| Redplating on one tube
More woes..! http://www.chambonino.com/carlsbro/carlcs100tc.html I heard a pop and then some hum, and the 3rd tube started redplating. If I turn the amp on, it doesn't redplate until I play a few chords. Could it be the 220k (carbon-comp) resistor that's causing it? I suspect it as the culprit. Other than that, what are the usual things that cause this? Any help is much appreciated as ever! |
| | #2 |
| Member Join Date: Feb 2008 Location: Long Island, NY
Yes, check values with meter for those screens, Take the tubes out and turn it on, and check voltages at the pins, especially the bias voltage and plate voltages. compare them against the schematic, should be fairly close. a resistor or diode could have drifted or failed in the bias circuit. check around those 220's & 10k's, bias circuit cap as well, especially if voltages are off. Then on your final test after you've verified good voltages and nothing looks burned up put in the tubes and you may want to use fresh tubes in case that one is cooked already
| | #3 |
| Old Timer Join Date: Jun 2007
| | #4 |
It's the same socket each time.. Wouldn't the bias supply make all the tubes redplate, or a pair of them? I've replaced the 220k, still the same... 10k checks out alright on a meter. |
| | #5 |
Also, seeing as it seems to wait until I've been playing for a couple of minutes to redplate, would a meter show up any incorrect resistances?
| | #6 |
Yes but weak tubes would redplate first (or more easily). With the amps that I've troubleshooted for redplating, I've encountered quite often the tubes biased too hot and there was one or two weak tube replating. If that wasn't the problem I just take voltages from the power tubes and work backwards, checking bias, and pinpointing the abnormality (unstable voltages usually for redplating). If I can't find it in the bias supply i will work from the tubes back to the PI checking voltages. This helps pinpoint the problem. Can't go around replacing every resistor!
| The Following User Says Thank You to darrellcheng For This Useful Post: | harry (03-31-2009) |
| | #7 |
Don't forget that if the 0.1 coupling cap leaks any positive dc voltage it will kill the bias to that tube socket as well. Also check the socket itself.
| The Following User Says Thank You to 52 Bill For This Useful Post: | harry (03-31-2009) |
| | #8 |
My mistake, it was a tube. I'd somehow managed to put it back in the same socket. Annoying though, I've only had the tubes about a month! Thanks for your help! Harry |
| | #9 |
| Senior Member Join Date: May 2006 Location: Alameda, CA, USA
Good idea, once you've had a tube redplate, is to check the screen resistor for that socket; also all pin voltages.
__________________ -Erik |
| | #10 |
If the screen resistors are what I think they are (the huge wirewound things), they look alright. Do they cause problems sometimes? These look indestructable! Actually I'm still getting some crackling/rustling when I turn the amp on. I have no idea what that is. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Wierd problem with blues Jr redplating | daz | Maintenance, Troubleshooting & Repair | 9 | 01-10-2009 03:41 AM |
| troubleshooting, redplating (+hum reduction on amp) | black_labb | Maintenance, Troubleshooting & Repair | 13 | 03-20-2008 12:54 AM |
| Reverb tube redplating | MickeyB | Maintenance, Troubleshooting & Repair | 8 | 03-08-2008 01:57 PM |
| SVT Bias changes with signal/redplating | rf7 | Maintenance, Troubleshooting & Repair | 1 | 12-29-2007 08:29 PM |
| MM PT in AC15RI, EL84's redplating. | petemoore | Mods & Tweeks | 2 | 12-04-2007 12:39 AM |
