Go Back   Music Electronics Forum > Amplification > Harp Amps
Old 04-14-2009, 05:59 AM   #1
Operadio PA amp, 5000 ohm output?
Hello,
I have an old Operadio 1A65. The schematic can be found here:
http://www.theused.com/resource/resource.php?curPage=27
I am wondering why the output impedence is so high? Is this really just a pre-amp? If so, what kind of power amp would accept this 5000ohm signal?
Is there such a thing as a 5000ohm speaker.
Any information is appreciated. Thanks!!!
cburbank is offline   Reply With Quote
Old 04-14-2009, 06:41 AM   #2
SOmeone might have a 5000 ohm headphone.
This is a line amplifier, not a power amplifier. Well, a PA system mixer really. That output tube is a 6SN7, and that isn;t going to power much speaker.
The output transformer allows you to match the output to a wide range of impedances, from 10k ohms (5000-0-5000), down to 125 ohms. You can drive a balanced line or a single ended line.
__________________
Enzo is online now   Reply With Quote
Old 04-14-2009, 07:06 AM   #3
Thanks for the reply!
So if it's very low output (I've noticed that myself,) is it really designed to drive a speaker directly?
If it is designed to go into a power amp, (even a solid state one) which taps would I use, and should I set it up for single ended or balanced line?
Ideally I would like to use this for background music, guitar, or as a vocal amp.
Thanks!
Old 04-14-2009, 08:44 AM   #4
It is a line amp, it is not meant to drive a speaker.
Experiment with connections to a power amp. If the amp has balanced inputs, try that, otherwise, single ended. Of single sided, start with as high an impedance as possible.
__________________
Old 04-14-2009, 08:39 PM   #5
Thanks again!
Any guidelines for impedance to use on the balanced input? Is there a typical range that power amps would be expecting?
How will I know if I'm off? Poor signal quality? Excessive volume or too quiet?
Naturally I don't want to fry anything on either end!!!
Old 04-14-2009, 09:53 PM   #6
Supporting Member
Steve Conner's Avatar
Yes, that's how you'll know if you're off: poor signal quality, excessive volume, or too quiet, or things getting fried.
I'd start with the 125 ohm tap and work up from there.
The output is transformer balanced, so it should be able to drive any kind of power amp input, either balanced or single-ended, without problems. It'll probably work best if you leave off the ground jumper mentioned in the instructions, unless your power amp isn't grounded.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
How to tell different ohm taps in an output transformer? slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 17 01-23-2008 01:06 AM
Rolls Passive Summing, 150 Ohm Output? RANDY Music Electronics 6 05-15-2007 04:54 PM
?8 ohm cab in parallel with 8 ohm dummy load? PlayItAll Guitar Amps 2 05-08-2007 05:10 AM
safely run 8 ohm speaker off 4 ohm amp? grandmasterflash213 Maintenance, Troubleshooting & Repair 1 04-17-2007 07:45 PM
Vox AC30 8 OHM & 16 Ohm? ArnC. Mods & Tweeks 2 11-16-2006 02:17 PM
