| | #1 |
| Junior Member Join Date: Mar 2009
| Buying and inductor to make a varitone
Hi everybody!!! Just a little question. Could anybody tell me where I can buy and inductor to build a varitone? Thanks a lot in advance. Iván |
| | #2 |
| Member Join Date: Apr 2009 Location: Nashville TN
I don't know the value of the vari-tone inductor, but Torres Engineering offers a vari-tone kit for $15.95. If the inductor you need is a 1.5 henri, you can get it for $4.95 with the "Torres Famous Midrange Kit". If you find a better source for these, would you please post it?
| | #3 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
You can get inductors from any electronics part suppliers, like mouser, digikey, jameco, etc. You can also use audio transformers. The one from RadioShack works ok.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| | #4 |
| Found one
Hi, Thanks a lot for your help. I found this one in Mouser (I believe is the one Dan Torres uses to build his varitones): 42TL021 Will that be fine? The thing has six legs...to be honest I don´t know what to do with so many of them. Has any of you any idea of how to connect this? Thanks, Iván |
| | #5 |
| Supporting Member Join Date: May 2008
The data sheet is on the link you provided. There is a center tapped primary, and a center tapped secondary. Either use the entire primary, or the entire secondary, and never mind the center taps.
| | #6 | |
| Supporting Member Join Date: Sep 2007
| Quote:
| | #7 |
In the book Electronics Projects for Musicians, Craig Anderton uses Mouser part 42TM-019 for the inductor. He uses the whole primary, and also has a switch at the tap for half the primary. The inductor in the Gibson L6-S was a 1/4" steel bolt, with three washer and a nut! They wound two coils between the washers so it was humbucking. I have the specs around somewhere, but it isn't hard to make.
| | #8 |
Although I've used these things for years, my understanding of them is a little foggy. If I were using a 1.5h inductor, a .033uf capacitor, and a 250k pot, which component (or combination thereof) would determine the frequency of the cut? Which would determine the depth? I don't have a strong background in math. If someone could explain it in layman's terms it would be greatly appreciated.
| | #9 |
I found this one on the 'net somewhere. This is for a standard Gibson 6-position Varitone: Position 1--> off Position 2--> -5db at 1950hz Position 3--> -12db at 1100hz Position 4--> -16db at 620hz Position 5--> -18.5db at 360hz Position 6--> -21db at 120hz Position 5 used a .03 cap. The L-6S guitar used a pot instead of a switch, and a .01 cap.
| | #10 |
| Just bought a Torres one
Hi, Well, I have just bought a Torres kit to make a varitone. When I got it I will post the value of the inductor here. Actually I believe he uses a small transformer. Regards and thanks, Iván |
| | #11 |
| Senior Member Join Date: Jun 2006
| So what did it turn out to be?
| | #12 |
| Transformer
Hi, It is a small transformer with the following writing on its body: TL021-R You can find these ones in Mouser. Regards, Iván |
| | #13 |
I measured a Radio Shack miniature output transformer (10K/8ohms) and the primary came out to .8H @ 1KHz. At 120Hz = 2.1H. Obviously, it will vary with frequency, but for anything in the right range, the cap used with the inductor is the part to experiment with. I'm using this set-up with a Telecaster in the neck position, approximating the Varitone 'Position 4'. The middle position = neck only and the back = Broadcaster Blender (Lollar CC set). Cool, cool, cool..... |
| | #14 | |
| Junior Member Join Date: Jan 2010
| Quote:
=1/ 2π(√CI) where is the frequency, C is capacitance, and I is inductance. you can go to Wolfram|Alpha and search "resonant frequency" for a calculator that will allow you to determine your various noth filters based on your inductor and whichever capacitors you choose. In order to vary the depth of the notch, wire the whole thing up to the tone control as if it was a single capacitor instead of a wad of components. Turning your tone control should vary the depth of the notch. | |
| | #15 |
dovedescending, thank you for your post and the link. I've built a number of these filters either "by ear" or by copying someone elses design. It will be fun to try again, going for a specific result. thanks again' thumbs |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Where can I get an inductor for Power Brake? | Ralle | Music Electronics | 9 | 05-22-2009 12:56 AM |
| caps for a varitone... | cigarboxboy | Guitar Tech | 7 | 02-13-2009 04:12 PM |
| More varitone questions | billyboy | Guitar Tech | 0 | 02-13-2009 04:09 PM |
| EQ inductor for old Fender | Enzo | Maintenance, Troubleshooting & Repair | 10 | 03-15-2008 12:46 AM |
| Bass Varitone | iassael | Guitar Tech | 3 | 10-14-2007 09:02 PM |
