| | #1 |
| Junior Member Join Date: Sep 2007 Location: Brattleboro, Vermont
| Channel Bleed on 5E3
Hi All, Sorry if I'm posting something that might be already covered. I lent my Mission 5E3 to a friend who's amp was in the shop and when I got to his gig he had his multi-effects unit set so high that there was feedback coming through the amp before he even played a note! After he returned the amp I've noticed that I'm getting a lot more channel bleed-through than normal. I mean, when I plug into the bright channel with the volume turned down and I turn up the normal channel I get a pretty substantial signal. Could my friend have fried a resistor or something in the am that I need to replace? Any thoughts would be appreciated. Aside from that I LOVE this amp. It's fantastic with my strat, tele and the PRS SE Custom. -Dave |
| | #2 |
| Senior Member Join Date: May 2008 Location: Webster NY
Unless your friends multi-effects unit was defective and applied an inappropriate voltage level to the input, it's unlikely it did anything wrong. If you really are hearing a significant difference from before, then perhaps something else happened cooincidentally. It does seem that it needs a checkup if it is indeed different. Outside of the bleed-through does it seem otherwise normal sounding? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Single channel 5E3 | Blindog | Tweed Builders | 18 | 08-08-2009 06:25 AM |
| MESA Maverick 2x12 (1993) Lead Channel Bleed to Rhythm Channel | StringBob | Maintenance, Troubleshooting & Repair | 13 | 02-08-2009 06:08 PM |
| Randall RG80-112sc Channel Bleed | timtaylor | Maintenance, Troubleshooting & Repair | 5 | 01-16-2009 09:13 PM |
| 5E3 - Why No Bleed Resistor to Drain B+? | haashole | 5 E 3 | 9 | 02-27-2008 04:02 PM |
| 5E3 Bright Channel???? | gtrbryan | 5 E 3 | 3 | 11-10-2006 11:19 PM |
