Old 12-17-2006, 12:37 AM   #1
Guitarist's Avatar
Traynor custom 40 low voltages
I replaced a buldging 450V cap but when the B+ rail hits a couple of 3 pin transistors the volts drop pathetically. Any one have a schematic for this or seen this issue? All tubes are pulled.
Now this is a high school amp but I'm considering bypassing these regulators etc and going simple/old school or giving it to an uber tech.
Thanks, eh.
Guitarist is offline   Reply With Quote
Old 12-18-2006, 01:09 AM   #2
You can download the full service package for the YCV-40 from the Yorkville website. You will see that the transistor in the B+ rail is the standby switching.
Tubebass is offline   Reply With Quote
Old 01-02-2007, 09:34 PM   #3
Early YCV40
If this is an very early YCV40 it may be missing a resistor and you will have repeat failure of the cap ! One of those crossed my path once .
Bruce is offline   Reply With Quote
Old 01-31-2007, 10:14 AM   #4
Guitarist's Avatar
Well, it working alot better now. I did the Taynor suggested circuit upgrades. High Voltages are back though I suspect it was a bad solder joint on the IRF 830 B+ regulator.
Now the only issue is after playing it for a bit say 5-10 minutes it belches out a loud .HUMMM. I've been testing the pre/loop out and they sound fine. Ever experience that rude honk?
thanks. guitarist
Ideas need for Traynor Bass Mate with EL84's podboy3 Guitar Amps 1 12-08-2006 04:45 AM
custom amp 15 glanny Vintage Amps 4 11-14-2006 12:26 PM
Measured Zoom G9.2tt voltages Guitarist Theory & Design 0 11-04-2006 10:34 PM
Traynor YGM-4 496dart Guitar Amps 2 07-31-2006 08:36 PM
Measuring voltages in a very high impedance circuit JC@ Theory & Design 4 07-04-2006 01:48 AM
