| Guitar Amps General discussion about amps |
| | #1 |
| Junior Member Join Date: Jul 2009
| Marshall power amp voltages
Hi Folks; Does anyone know what voltage the secondary windings on the T4145 mains transformer used in the 100 watt Marshall power amps are? I have googled the world but this seems to be the BEST kept secret in the world. This seems daft as I'm hardly going to wind the transformer myself and will end up buying one but I would like to know . I'm guessing the HT is about 470 volts. The heater winding is 6.3 v (no secret there) I believe the winding with the white output lead is 100 volts (and I'm guessing that's supplying grid bias to the four EL84 power tubes. power handling for the mains transformer should be 200 Watts. Any helpful soul out there who can confirm? Thanks Mike |
| | #2 |
Be fair to Marshall. They don;t bother to publish voltage and current specs because they already told you the proper transformer is the T4145. But if you want to find one on your own, consider that it is a 100 watt amp with four common power tubes. There is nothing to make it any different from ANY 100 watt four power tube amp. They all run in the 475-500v range, they all need the same current for the 100 watts, and they all need about the same current for the preamp. They may or may not have a bias winding or tap, but if they do, it will be about the same for all - maybe 50v. But all that aside, if you want 470VDC, and you are not using a rectifier tube, then you are going to need about 335VAC, or 770VAC-CT. That depends upon your rectifier choice.
| The Following User Says Thank You to Enzo For This Useful Post: | mike3124 (07-18-2009) |
| | #3 |
| Thanks Enzo
What you say is true, Marshall do provide the part number but I wanted to understand what and why. You have helped with that and I appreciate it. Thanks Mike |
| | #4 |
And welcome to the forum.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Trouble with old amp: voltages too low. Bad power transformer? | slidincharlie (Carlo P) | Maintenance, Troubleshooting & Repair | 15 | 11-28-2007 08:48 AM |
| Marshall VBA400 power amp voltages | TDS | Maintenance, Troubleshooting & Repair | 0 | 07-01-2007 01:39 PM |
| marshall slx power amp oscillating | swt | Maintenance, Troubleshooting & Repair | 2 | 05-23-2007 05:31 PM |
| Marshall 9100 Voltages? | Gregg | Maintenance, Troubleshooting & Repair | 7 | 04-13-2007 10:12 PM |
| 5E3 Power Mod Voltages | Mikeb | 5 E 3 | 6 | 03-02-2007 04:08 AM |
