| | #1 |
| Junior Member Join Date: Sep 2009 Location: The Netherlands
| Variable cathode resistor
Hi, This is my first post here. Since I can't find hardly any decent information about this idea/mod I thought I might ask you for some input on this subject. I'm planning on building a SE guitaramp with only two gainstages. There are several common ways of controling the amount of overdrive (at lower volumes), but I was wondering if this would do the trick as well: Why not make the cathode resistor of the second gainstage variable? In theory the higher the value of the cathode resistor, the less gain and the more overdrive you will get from the gainstage. But will this work properly in real life, or are there certain side issues you have to consider? Has anyone experimented with this idea? Last edited by Rutger; 10-15-2009 at 12:10 PM. |
| | #2 |
No reason you can't try it, but having the DC tube current in the pot you'd have to have would result in a scratchy sounding pot.
| | #3 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
I used a variable cathode resistor in the first stage of my old Ninja Toaster amp. Even though it used a capacitor to remove DC from the pot, it was still scratchy, and changing the capacitor out didn't seem to make any difference. I replaced it with a mini rotary switch and network of fixed resistors.
__________________ "Transformerless is the way to go", said he, without a hint of irony. |
| | #4 |
Thanks! Good idea, I will use a rotaryswitch with fixed resistors @Steve: I had in mind to vary the actual cathode resistor (which is typicaly 1,5k) and put a 22u cap in paralel. In theory the gainlose would be minimized by the cap while increasing the value of the cathode resistor. Should that work properly? |
| | #5 |
That doesn't make sense. In your first post, you said that you wanted to decrease the gain by increasing the cathode resistor. Now you say that you want to avoid gain loss when you increase the cathode resistor. Bypassing it with a 22uF capacitor would certainly avoid gain loss, but it seems to me it would defeat the purpose of the whole thing. It's negative feedback across an unbypassed cathode resistor that lowers the gain. If the resistor is bypassed, the gain won't change, except in so far as the tube's own gain is a function of its bias point. But that's a second-order effect. My circuit does the opposite, it changes the AC gain of the tube without moving the DC bias point.
| | #6 | |
| Quote:
Actually the purpose of my idea is to move the DC bias point, so the tube will distort easer. I understand there will be some loss of gain by doing this, but that's more of a side effect. By keeping the gain as large as possible by bypassing the cathode resistor, the loss of gain will be limited. I just want to make a simple SE design a little more versatile by doing this. I'm wondering if that makes sence or if it's just a stupid idea... Last edited by Rutger; 10-15-2009 at 09:00 PM. | |
| | #7 | |
| Senior Member Join Date: Apr 2008 Location: PDX
| Quote:
I built a little variable parallel cap (w series resistor) to try on my cathodes. tants but they're not the antichrist some say they are. | |
| | #8 | |
| Junior Member Join Date: Aug 2008
| Quote:
What's the idea behind this design? Wide, flat frequency responce? How does it sound, any clips? | |
| | #9 |
| Member Join Date: Apr 2009
| | #10 |
Rutger: I'm sure that would work, if that's what you're trying to achieve. In another amp I built, I applied combination cathode and fixed bias to one of the preamp tubes. I used the main power tube bias supply, reduced by a zener, and a little pot to adjust the bias on that stage. It certainly did change the character of the overdrive. paolo: I used a 12AX7. Never thought to try the stage with a 12AU7. A 12DW7 would probably be best, because the second stage needs all the gain it can get to make the tone controls work. I also never thought of the first stage operation as being a kind of bootstrapping, but I guess it is. tedmich: The idea behind the undersized cathode bypass cap is to get a kind of Tube Screamer effect. As you turn the gain boost up, it boosts mids and treble more than it boosts bass, so it doesn't get so farty. This amp was built in 1999, so it predates Merlin's book by a long time. You can hear it here: http://scopeboy.com/music/mp3/Way%20...%20Worrier.mp3 and here: http://music-electronics-forum.com/a...lve-test-1.mp3 It's hard to say what it sounds like because it's so configurable. When I built it I was into metal, and I would use all 5 gain stages and use the EQ for a mid scoop, to get that kind of nasty Boogie grind. Now I'd tend to use 4 stages and boost the mids instead. The little tantalum guy looks scary! :-O
| | #11 |
Thanks Steve, great help!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Different Resistor/Cap Configurations at the Cathode | shef86 | Theory & Design | 7 | 12-30-2008 01:36 PM |
| Where best to locate the variable resistor for the 5150 bias mod | 7 DYing Trees | Mods & Tweeks | 6 | 01-25-2008 02:43 AM |
| Cathode Resistor values for OD channel | tubeswell | Mods & Tweeks | 7 | 05-14-2007 09:09 PM |
| Variable cathode bias? | Satamax | Guitar Amps | 4 | 12-12-2006 06:24 AM |
| Cathode follower cathode resistor question | Mark Buckingham | Theory & Design | 9 | 10-10-2006 01:12 AM |
