Old 10-17-2009, 08:37 PM   #1
EH EL34 heater-cathode leakage
I'm working on a Marshal JCM800 2210 head, and the EL34s in it are Electro-Harmonix production branded as "Mojotone." (It only has two EL34s in it since the owner likes to run it as a lower-wattage amp, but he does set the output impedance to compensate.)
Both EL34s show exactly the same amount of heater-cathode leakage in my EICO tester, ~5 Megohms. Is that typical for these? I have just about every other brand of EL34 in my possession, and they show virtually no measurable leakage.
Otherwise, the tubes test and work just fine.
Thanks,
David
Rhodesplyr is offline   Reply With Quote
Old 10-18-2009, 08:34 PM   #2
Euthymia's Avatar
Thanks,
David
I am recently seeing the same thing using my EICO 667. My tube supplier says he is looking into it, but for the moment, I'm treating the tubes as "good."
They work fine in amps, which is really the proof. If my clients have problems with them, I'll swap their tubes out.
__________________
-Erik
Euthymia is offline   Reply With Quote
heater to cathode voltages tubeswell Theory & Design 1 08-12-2009 01:50 PM
el34 pp cathode bias amp clip and Power supply // earth ground question rexindigo Guitar Amps 5 11-26-2008 10:34 PM
Proven Design for Cathode Bias EL34 PP rexindigo Guitar Amps 10 09-26-2008 12:41 PM
Coupling Capacitor Leakage Current? tbryanh Theory & Design 2 04-13-2007 01:29 AM
Cathode bias el34 design stevesamps Theory & Design 1 12-12-2006 04:53 AM
