| | #1 |
| Junior Member Join Date: Oct 2009
| Bugera Problem
My bugera 333 xl is died on me the other day but not in the way everyone elses does 1.The Power and standby lights dont turn on 2.The tubes Do glow when the power is switched on 3.When i turn it off standby it blows the fuse Any ides? |
| | #2 |
| Member Join Date: Jun 2009 Location: Germany
Seems like on of your tubes causes a short on the HV. Remove all tubes,inspect them carefully for any signs of arcing, get a new fuse and power on => if fuse blows there is a issue in your HV supply, get it to a tech=> if not power off, insert first tube, power on, turn standby off => fuse stays in, good => repeat procedure until fuse blows then you have found the bad tube, if not, congrats you found the bad tube on the first attempt... cu bluesfreak
__________________ I can fix everything, where is the duct tape? Last edited by bluesfreak; 10-31-2009 at 05:33 PM. |
| | #3 |
Thanks man. I forgot to mention there is a hum before it blows the fuse. Also by arcing do you mean like lightning? Lol
| | #4 |
Yeah, something similar. HV arcing in a socket or within the tube usually leaves visible, charred traces...
__________________ I can fix everything, where is the duct tape? |
| | #5 |
| Member Join Date: Nov 2008 Location: Santiago, Chile
There is a wire connected on those amps that looks just like an HD IDE cable the wire is too thin to carry the right amount of current that ends up overheating and literally burning itself.. It's often a common failure on these amps.. let it discharge for about a day. then open that amp upī. Before that take out the power tubes and label them so u put back in the same order. Then measure with ur DMM DC voltage on pin 3 of each power tube socket. That will tell u if there is any voltage left on the filter capacitors. double check it. It's safe under 20 volts or less . You can also hit the standby switch , this connects a pair of capacitor to the rest of the circuit and lets them to discharge a bit faster. If u can take picture of the inside of that amp would be helpful i bet that is the same problem that every bugera has.. Good Luck! |
| | #6 | |
| Member Join Date: Jan 2009 Location: L. Panasoffkee, FL
| Quote:
__________________ CharlieP Peavey VK 112 2008 Marshall 250 DFX 2007 Met. Red LP Gibson Robot 2008 Faded Cherry LP Gibson 2007 Fender Strat HSS LSR S1 2008 Pearl Gretsch G5120 2007 Black | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Bugera 333xl-212 big problem | j@c3k | Maintenance, Troubleshooting & Repair | 24 | 02-05-2010 11:40 AM |
| Bugera V22 | KingBiscuit | Guitar Amps | 6 | 09-10-2009 08:31 AM |
| Bugera 333xl 212 combo problem | sclemmer | Maintenance, Troubleshooting & Repair | 16 | 06-21-2009 05:44 AM |
| Bugera scem | Valvehead | Schematic Requests | 2 | 05-15-2009 03:48 AM |
| Bugera 333Xl 212 Huge Problem | midnightmassacre92 | Maintenance, Troubleshooting & Repair | 3 | 05-12-2009 02:40 AM |
