Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 11-01-2009, 06:18 PM   #1
'65 Twin Reissue Mods
Anyone know any good mods for a Fender '65 Twin Reverb Re-issue?
Thanks!
deathofaparty is offline   Reply With Quote
Old 11-01-2009, 06:44 PM   #2
I would like to know some mods too. thx
Braxxen is offline   Reply With Quote
Old 11-01-2009, 08:28 PM   #3
Tom Phillips's Avatar
Quote:
A question phrased that way could get you an avalanche of answers or... no answers.
It would help if you post what you are trying to accomplish.
Regards,
Tom
Tom Phillips is offline   Reply With Quote
Old 11-01-2009, 10:37 PM   #4
Obviously any good mods for the non re issue Twin Reverb should also be good for the re issue. Some Google searching should reveal plenty. If the goal is to make the re issue more like an original then I'm sure that's been worked on too. Again, some Google searching should do it.
Torres Engineering does a full eyelet board rewire to original BF layout, very cool. Maybe it's sold as a kit if you would like to DIY. Otherwise, there are a buttload of "BF" mods around and most should translate to your amps circuit easily. Though the printed circuit board in those amps may make some things harder than others.
Typical mods would be heating up the "normal" channel for more OD, reverb on both channels, bright switch mods, mid boost ala Rivera style, triode/pentode, etc, etc...
Like Tom asked, what do you want?
Chuck
Chuck H is offline   Reply With Quote
Tags
mods, reissue, reverb, twin
Fender 65 twin reverb reissue mods j_man1974 Mods & Tweeks 3 03-31-2009 01:30 AM
65 Deluxe Reverb Reissue rdoyle Guitar Amps 9 01-27-2009 04:14 AM
65 Fender Twin Reissue - No Reverb tommyg Maintenance, Troubleshooting & Repair 12 10-20-2008 03:40 PM
65 Deluxe reissue pots Daveg Maintenance, Troubleshooting & Repair 2 04-17-2008 12:13 PM
'65 Fender Twin NOT REISSUE Popping on Power Up and Power Down keysnleslie Maintenance, Troubleshooting & Repair 8 10-31-2007 07:32 AM
