Results 1 to 4 of 4
Thread: replacement power transformer for Spectra 212-T?
    Oct 2006
    26
    I need to replace the power transformer in this Spectra 212-T amplifier for a friend. It's definitely shorted out, as shown by using a current limiter. The amp uses 4-6L6 and 4-12AX7. Any recommendations/sources for a good replacement?
    Senior Member Twist's Avatar
    Nov 2007
    Springdale, Arkansas
    314
    Refresh my memory, does that one have OpAmps too? If not, then something similar to a Fender Twin power tranny would work. Of course you need to compare mounting dimensions. Try Antique Electronic Supply . Look up part number P-T290FX . If it does have a low voltage supply for the pre amp then you may have to be a little creative and add a smaller tranny for that part of the power supply. I haven't seen a Spectra amp around here in years.
    Oct 2006
    26
    Quote Originally Posted by Twist View Post
    It has op-amps in the reverb driver and recovery circuits. It uses the HV tap to do the bias and supply the op-amps w/ +/-18vdc. That transformer looks like it might do the trick.
    Oct 2006
    26
    I picked up a Hammond replacement transformer for a Fender Twin that I think will work. Specs here: 01 - More Info for item P-T290FX
    The problem I have now is the new one mounts thru the chassis unlike the original which had upright mounts. The bell ends of the original are exactly the right size for mounting on the new transformer but not deep enough on the one side for all the wires. Is there an acceptable method for shimming the bell so it can clear the wires?
  1. Anyone remember these? (JMF Spectra)
    By pchilson in forum Guitar Amps
    Last Post: 11-24-2010, 08:02 PM
  2. fender hotrod deville 212 trouble! (no power)
    By highwaychile1970 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-20-2010, 08:14 PM
  3. Markley CD-120/JMF Spectra Channel Switching
    By Rhodesplyr in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-05-2009, 03:37 AM
  4. Stage 160 pre amp into FM 212 power amp question
    By noviceamptech in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-17-2009, 01:08 AM
  5. HR DeVille 212 Reverb and power loss
    By Teleman55 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-11-2007, 12:45 AM
