So look at the circuit that controls them. When those turn on, the signal path is shunted to ground, so sure, no noise comes out. They are controlled by CLAMPC.
CLAMPA and CLAMPB are merely taps off the footswitch circuits. When you stomp a switch, onie of those is pulsed. Ultimately rthe little circuit decides if one of those will send a pulse to little triac CR102.
When CR102 fires, it conducts, grounding CLAMPC and thus the gates of Q5,Q7. Grounding the gates of those JFETs lets them turn ON, and shunting the noise signal.
The trigger pulse to CR102 comes through a cap, so it is not steady. The JFETs will stay ON until R200 has a chance to recharge C200.
SCope the gate of on of the JFETs and watch that muting pulse. It may or may not be there, and you deal accordingly. Also the JFETs themselves could be the issue, a shorted one could kill the whole clamp operation.
LinkBack URL
About LinkBacks
