Results 1 to 8 of 8
Thread: Old Hammond Tubes??
    Dec 2009
    Nashville, TN
    149
    Old Hammond Tubes??
    Another casualty of the Nashville flooding is an old Hammond organ at the neighbors. It's not a B3, but one of the church style ones. It's sitting on the curb, and I think I'm going to nab it. It has a bunch of hammond branded tubes in it...GZ34, 12AX7, EL84, something that looks a lot like a 6V6 but has weird looking plates with copper, and some others. Also I'm sure the transformers are worth getting. Anyone know anything about those tubes. I've seen a couple things online suggesting they are rebranded mullards, which might make them a pretty sweet find.
    EDIT - It's one of the H-100 models from mid 60s-mid 70s.
    Phoenix
    687
    Yah! Most of the components should be ok after cleaning and drying. There may be some bumblebee caps inside as well. The tubes will be fine even if nothing else is.
    Feb 2010
    60
    They (Hammond), just like many of the other organ manufacturers used rebranded tubes of different manufacture. They could be Mullards, or RCA's, or Ge's...really depends on what supplier was used in a given year.
    I go though a lot of salvage organs, and even see mixed brands within the same organ.
    If it has bumblebee caps in it, it was made between '58 to '62...I would venture to make an educated guess they woould be RCA's...which are excellent tubes. Later than that you would probably see black beauty sprague caps...and in that case probably the Mullard's or GE's.
    Oct 2006
    CT - USA
    145
    Whatever the manufacturer, tubes selected for organs (I guess we're talking mostly preamp) had to be non-microphonic, so you know they're good in that respect.
    Senior Member CharlieP's Avatar
    Jan 2009
    L. Panasoffkee, FL
    131
    Sounds like a treasure trove!
    CharlieP
    (2)Peavey VK 112 2008
    Fender SuperSonic 60W 112 2010
    Met. Red LP Gibson Robot 2008
    Faded Cherry LP Gibson 2007
    Fender Strat HSS LSR S1 2008 Pearl
    Fend FSR Tele Dlx Candy App 2011
    Gretsch G5120 2007 Black
    Member roughcut studios's Avatar
    Apr 2009
    boston
    50
    those are 7591's. Used in some Ampegs and a bunch of hifi stuff. They go for fairly good money on fleabay. ...Jon
  7. #7
    Dec 2008
    580
    Yes, there were a lot of Hammond casualties in the flood--a good friend of mine who owns Nashville Pro Hammond got hit hard.
    The H-100s had monster power supplies--huge power transformers and nice chokes--and they usually had two Mullard GZ-34s in them. Of course, if the power transformer got flooded, it can be bad news. If the octal tubes got flooded, you'll have to make sure that 1) there's no conductive junk inside the tube base and 2) it gets completely dried out inside the tube base. Miniature 9-pin tubes should be fine. Output tubes as someone else said are 7591s.
    I tried to bring back a Hammond organ preamp that got submerged in Katrina, but I gave up. The nasty thing about floodwater is that it's usually DIRTY water. Theoretically, you should be able to dry them out, but it doesn't always work out that way...
    Hammond never used "bumblebee" caps, as far as I've seen. They usually used RCA small signal tubes. All original EL84s I've seen in Hammond amps are Amperex/Holland.
  8. #8
    Apr 2009
    boston
    50
    flooded hammonds
    I have a couple of those h-100 power supplies and main amps if anyone needs transformers to repair one of those beasts. P.M me.
  1. Hammond L-100
    By otto pärt in forum Conversion Projects
    Last Post: 05-24-2013, 07:01 PM
  2. hammond tubes question (help needed)
    By ecoman35 in forum Guitar Amps
    Last Post: 02-22-2010, 03:52 PM
  3. hammond tubes question
    By ecoman35 in forum Tubes (Valves)
    Last Post: 02-06-2010, 10:29 AM
  4. Hammond-labeled tubes - mfr?
    By Don Moose in forum Tubes (Valves)
    Last Post: 10-15-2009, 04:29 PM
  5. Hammond 1750N...anyone used one
    By daz in forum Theory & Design
    Last Post: 09-29-2008, 09:23 AM
