Results 1 to 5 of 5
Thread: Odd voltages
    Dec 2009
    30
    Odd voltages
    The voltages in red were measured with the load and bias listed on the schematic.
    The resistors check within tolerances, what else might cause the variation from the schematic?
    Should I adjust the 12k-3w and the 33k to make it work?
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,066
    It doesn't work now?
    Most old Fender schematics had a warning printed on them that voltages are approximate and may vary 20%. Your voltages are not off all that far. And mainly just B+4. If you apply Ohm's Law, I think the currents will appear pretty normal.
    When you have 220k plate load resistors and less than a milliamp plate currents, it doesn;t take a lot of tube variation to cause a large voltage change.
    Dec 2009
    30
    It works better then ever with the changes so far, however, I don't want to modify the power section until I know it's working properly. I normally bias at .3v (21w) bringing the 6l6 plates up even more so I was thinking of reducing the 12k 3w before discovering the discrepancies.
    Do you mean determine the amperage across the plate resistors with I=E/R?
    The specs for 12ax7 state Plate Current 9mA-.75mA and if I understand correctly both 6l6's 116mA with no input.
    18,066
    No, I mean if there is a 220k plate resistor with 123v on one end and 260v on the other, how much current must be flowing in that resistor? And does that make sense? (In your case, a little under 1ma is not unusual at all for a 12AX7) And if there are three 12AX7 triodes drawing from B+4, does that seem to agree with the V drop across the B+4 resistor?
    I see nothing wrong, so what do you see as a problem here?
    Dec 2009
    30
    That's what I thought (.62mA) but I did not see the specs are for 250v plate so the min would change to .37mA at 123v (I assume)
    True it is within 20% but 50v out of spec seems like a lot to a novice.
  1. New 5F6A Build with Odd Voltages and Loud Buzzing
    By jim911 in forum Tweed Builders
    Last Post: 02-21-2010, 05:46 PM
  2. Odd find
    By Enzo in forum Music Electronics
    Last Post: 01-19-2010, 11:12 AM
  3. Boogie - odd voltages
    By txstrat in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-23-2009, 06:50 PM
  4. 5E3 Build Odd Voltages Question
    By jim911 in forum 5 E 3
    Last Post: 03-15-2009, 06:15 AM
  5. Odd Harmonics
    By chunkitup in forum Theory & Design
    Last Post: 08-06-2007, 06:01 PM
