Originally Posted by
MWJB Looks like there is a drain on the power supply somewhere.
If you suspect the filter caps, and you have spares, it won't take long to change them and eliminate them as the problem. Look for any blobs of solder that might be causing any accidental grounds from the power supply.
Pull all the tubes except for the rectifier. Then measure voltage at pin 8. Does it bounce back up? With 317VAC at each pin 4 & 6 of the recifier, I'd be looking for 350vDC-ish with a 5Y3. Note that with no tubes installed there won't be much voltage drop as you go further towards the front of the amp, so don't panic if you try and measure preamp pins and they all read high.
If the voltages are still low, you have a short in the power supply (this is where a variac or "lightbulb limiter" comes in handy when powering up for the first time).
If you're getting 350v-ish at pin 8, then fit V1. If everything is still OK, fit V2.
With both preamp tubes fitted voltages should be more in line, then fit "known to be good" power tubes and check again.
With a 250ohm cathode resistor, at 275v "plate to ground" volts, I'd be surprised (and a little alarmed) if your power tubes were drawing much beyond 30mA. Certainly shouldn't be drawing 50mA+.
