Originally Posted by
zephedone
I'm no guru or even a technician by any means ....
I have two 710 models that I found for under $10.00 . They don't look exactly like yours but very similar .The first one I gutted and put a 12" speaker and a modified Magnavox 196 console chassis in the empty cab . It runs two el84s a 5y3 and two 12ax7s . I used the PT for a PP 6v6 amp that I built into an old Peavey SS amp that was donated to me . That PT is putting out 360-0-360 vac .The second I just aquired . Am thinking about using the Xfrmrs for a SE Champ style amp with tremolo in a head configuration . I don't know what speaker is in yours but mine had a 6x9 and a small tweeter . I'm broke so , if you are like me , on a low budget , with a little work you can use everything in that old hulk but , I would transfer it to a new chassis at least as "olddawg" suggested . I have pics of what I did to mine if you want to see them . It aint real pretty but the second one I have will be much improved from what I've learned on the first build . Good luck .......
