Page 1 of 2 12 LastLast
Results 1 to 35 of 57
Thread: 12AX7 HUM
    ToneOholic! big_teee's Avatar
    Jun 2010
    U.S.A.
    4,441
    12AX7 HUM
    Occasionally I come across a 12AX7 tube that Hums in my amp.
    I just bought a $16.95 new issue Mullard 12AX7 and it hums in V1.
    I had some 3 year old Tung-Sols, and they are very quiet.
    What causes the Hum on certain tubes, and can't that be found when the seller tests the tubes?
    Terry
    Keep Rockin!
    Terry
    Jun 2006
    3,313
    It can be found by the seller if they check for it, in high gain amps & reverb channel (V" in BF/SF Fenders springs to mind)amps. Sometimes sellers advertise "7025/low noise" variants of 12AX7, sometimes these are just a low gain tube like the Sovtek 12AX7WA or sometimes a regular gain 12AX7 that has been screened for noise/microphony. Try the noisy 12AX7 in a less noise critical position in the amp like a phase inverter, or a tremolo tube and buy another screened tube for V1.
    May 2007
    pacific north west
    5,890
    It's been my experience that when the same 12ax7 has very dissimilar gain or bias on each triode there can be an increase in hum. Like the cathode follower tube in Bassman/Marshall type amps or the cold clipping stage in high gainers. The solution the high gainers use is to employ DC preamp filaments or sometimes a tricky sort of false lead off one side of the filament wind used to tune out the hum by manipulating where it's radiant field is in the amp for more effective cancellation in twisted pair circuits. There was the "hum balance" control used on SF Fenders too. Limited, but an improvement over nothing at all. Then there's the DC biased twisted pair. Can be very effective if the DC elevation is high enough to render the imbalance insignificant. Usually 30-40 volts does it. My solution has been to select tubes that are imbalanced in the right way that the hum balances in these troubled positions. I can usually find one that's pretty quiet for any troubled socket.
    FWIW I have noticed a huge increase in new tubes being prone to hum. I think it's sloppy design. On he up side I also think that overall preamp tubes are sounding better.
    "I should have been born sooner. Of course, if I had been, I might be dead now." trem
    Jun 2010
    U.S.A.
    4,441
    Quote Originally Posted by Chuck H View Post
    Your correct on the type of amp.
    It's my new 2204 on High input, which uses 4 gain stages I believe.
    I have had a tough time sorting out the hum, but some tubes are better than others.
    Right now I have the Filament center tap taped up and connected 100-200 ohms to ground to each side of the 3.1Volts.
    The 200ohms seemed the quietest.
    Re did the grounds and that helped.
    I think the DC would be the best bet, but don't know how to accomplish that with what's in the chassis!
    I've re-routed and checked everything.
    It's coming from V1.
    You can ground the sig input to V2 and all is quiet.
    Terry
    Keep Rockin!
    Terry
    Old Timer Gtr_tech's Avatar
    Nov 2007
    Owosso, Mi
    1,537
    A master vol (jcm800 type) 220* has 3 gain stages in the front end.
    Jun 2010
    U.S.A.
    4,441
    Quote Originally Posted by Gtr_tech View Post
    I believe you, but can you explain!
    I thought on high it uses both V1A, V1B, and both V2 Stages.
    Where am I going wrong?
    Terry
    Keep Rockin!
    Terry
  7. #7
    Nov 2007
    Owosso, Mi
    1,537
    When you plug into the "high" input, all 3 stages are used. With the "low" input, the first stage is skipped and signal goes straight to the second stage. Thats why it sounds muffled and crappy plugging into the low in.
  8. #8
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    2,892
    I like the reissue Mullard and Tung-Sol 12AX7s but I also have had what I think is an abnormally large number of them being hummy... I don't know why.
    They still sound pretty good but the hum us objectionable to some people... until they play on stage or with other musicians...
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  9. #9
    May 2007
    pacific north west
    5,890
    Yes, we (guitar players) get a little fussy when we're practicing at home and are allowed to focus on the constant hummmmmmm... Probably not as big a deal as we make it out to be. Still, there are a lot of reasons amps hum. If the tubes are hummy I can get over it a little better, but... I built a new amp, my standard model, for someone and as soon as I flipped the standby switch "HUMMMMMM". I spent about an hour going over my circuit and grounds. I've built six of these so the fact that it was built, grounded and layed out just like the others and working fine had me confused. Finally the light went on. I tried a different V1 and 'ta da' no more hum. It was a brand new Sovtek right out of the box. I've unboxed several others since with similar issues as well as a few other brands. I use to get all my preamp tubes via salvage at a local electronics junk yard. As in 'used tests good' for about a buck each. Then I would test them in an actual amp for microphonics and tone. Even these "junk" tubes never had the hum ratio per capita that current new tubes do. It's sad IMHO.
  10. #10
    Old Timer soundguruman's Avatar
    Jul 2011
    California
    1,682
    Higher gain tube more hum, higher gain amp more hum,
    But all you had to do was make the heater supply for the first two tubes into DC. Now the hum is gone and the gain is on?
    You can learn a lot from those Hi Fi Guys. Ceramic disk capacitors can also induce hum into the audio path, from the AC field around the heaters.
  11. #11
    Jan 2009
    Denver, CO
    72
    Quote Originally Posted by soundguruman View Post
    I don't follow this. I understand ceramic disk capacitors can introduce noise into the audio path through being microphonic, but how does the AC field around the heaters play into that? Microphones sense the vibrations of a sound and turn them into electrical signal. So if the caps were vibrating, I could see them being a source of hum. But an AC field is not a mechanical vibration. If the hum were entering into the signal path via some kind of capacitive coupling from the heaters to the ceramic caps, I might buy that, but then wouldn't *any* capacitor be susceptible to such, not just ceramics?
  12. #12
    Jul 2011
    California
    1,682
    OK you asked for it...
    Ceramic disk caps induct 60 cycle fields, and inject that 60 cycle right into the audio path. That's why you should replace them, particularly, if they are used in the audio path.
    These are most noticeable in the application of the "bright" cap used across the volume control, or on the "bright" switch. Also the hi pass filter, used for the treble control. You will also spot these in other places, within the circuit. The closer the cap is located to the input stage, (or IN the input stage) the more 60 cycle will be introduced into the audio path.
    The 60 cycle surrounds the heater wires, where these are used for the preamp, is inviting 60 cycle to be amplified.
    That's one big reason we use DC heaters, especially for the first two stages of the preamp. The 60 cycle does not have the opportunity to enter the highest gain stages of the preamp, and therefore, is not amplified.
    You are puzzled as to why a capacitor can INDUCT? I thought capacitance was the opposite of inductance.
    They do, in fact modern capacitors are deliberately designed to be "non-inductive." The capacitor acts as an inductor at frequencies outside of it's intended operating range. It's just like an antenna. The antenna picks up 60 cycle, from the heater wires mainly, or the power transformer. There is no shielding to prevent it on a ceramic disk.
    Your guitar pickups, pick up 60 cycle, from electrical equipment, and that 60 cycle is amplified also along with the music. Same exact problem.
    Trivia: In silver face and black-face fender amps, you will always notice a low, 60 cycle hum, especially when the amp is cranked up.
    Guess where at least half of the hum be coming from? If you do not know by now, start at the top and read again.
    Notice: In an amplifier the parts talk to each other. They do not care where the wires go. Try for a moment to realize there are many other signal paths besides the ones connected by wires.
    Any time you put two wires side by side, you have made a capacitor. Now the AC traveling through those wires is mixed together, it does not care if the AC is 60 cycle, music, anything, it still mixes together. Not the current, but the voltage, yes. Now that the 60 cycle has entered the audio path, it is amplified, you hear hum.
    There is AC voltage on the chassis of your amp. It is not a lot, but it's there. Now you are laying a wire on the chassis. That tiny little AC voltage is inducted into the wire, and amplified.
    that is why, if we want low noise, we need to start with non inductive capacitors and non inductive resistors. Then the parts talk to each other less.
  13. #13
    Jun 2010
    U.S.A.
    4,441
    I don't follow any of that Logic Either!
    Chuck, Bruce, JazzP Help!
    B_T
    Keep Rockin!
    Terry
  14. #14
    Dec 2008
    Wernersville, PA
    5,369
    The subject of hum, as related to the heater & cathode is covered very well in this piece.
    There is talk of "why" the 7025 was what it was.
    Selected.
    I do not know if the current tube manufacturers have the "tact" that was developed at the height of tube production.
    What with "grading" output tubes for this or that quality (when actually the tubes should be pitched)
    And GT with all of there 12AX7 xxx tubes.
    Maybe they are "selecting" them.
    The full booklet is here.
    Getting The Most Out Of Vacuum Tubes
  15. #15
    Senior Member km6xz's Avatar
    Dec 2010
    St Petersburg Russia
    861
    Have you measured this effect? I find it hard to believe that considering differential mode active stages have so many "difference" noise sources that such minuscule contribution by ceramic caps several diameters away from the twisted lead heater wires. The only effective difference field is the imbalance of current between the two twisted wires. That is why they are twisted, to cancel such field induction. There are too many real difference mode sources of higher amplitude in the circuit to be that concerned with tiny common mode imbalances.
    There are other reasons that can be measured as to why ceramic caps are not advised for audio signal paths such as their piezoelectric properties producing varying instantaneous values of capacitive reactance. The non-linearity that results increases inter-modulation in complex signals. The same piezo property of ceramic caps results in micro-phonics.
    I would be interested in seeing and studies or measurements that was the basis for the conclusion that ceramics are any more susceptible to fields than say wires or other passive components.
    By any criteria, differential signal paths in such high gain circuits as guitar amps, which usually strive for very high input impedance, it is a miracle that amps are so quiet. Only a few builders have tried to do the logical thing of creating an all common mode path, balanced line, pickups, H-attenuation and gain stages but it never caught on despite all its advantages.
  16. #16
    May 2007
    pacific north west
    5,890
    Quote Originally Posted by km6xz View Post
    Ha ha. That's because it almost cant be done without the need for at least a little user awareness. Some guitar players have no trouble with this. But most, well, most get confused by hi/lo inputs or an adjustable effects loop. I have customers that are stupified by the noise of single coil pickups or try to use a speaker cable for an instrument cable, or a battery dies in their guitar or effect pedal and think their amp is broken. I even had one customer who thought something was wrong with his amp because it didn't have the same gain level anymore. He had flipped the gain switch on the back of the amp in transport and had forgotten it was there. I'm just sayin', put more than four knobs on an amp and the average player needs a lot of time to dial in and understand what to do just to use an amp.
  17. #17
    Dec 2008
    Wernersville, PA
    5,369
    Ha Ha!.
    I forget exactly which model it is, Mesa Boogie has a speaker mute switch tucked under the rear of the chassis.
    Pick up the amp the wrong way & "click".
    (It worked last night & now nothing!)
  18. #18
    May 2007
    pacific north west
    5,890
    Bwaaaahaahahahaha.
    That happened to ME. After extensive mods to a Subway model. It sounded great and I meant to loan it to a friend. I brought it to his house and plugged it in to show it off and "What the, ???, I don't understand. It worked just an hour ago."... "I" had forgotten about the switch and had flipped it during transport. My friend, who knows I build and mod amps just looked over his nose at me. "Well, I guess you'll have to go in there and find out what you broke." Ha.
  19. #19
    Dec 2008
    Wernersville, PA
    5,369
    Something about "never show it off" or "never brag about a repair" or "never ask how it is working"
    Karma or somesuch thing.
  20. #20
    EFK
    EFK is offline
    May 2008
    691
    I have to agree with the ceramic cap comments - I certainly don't know nearly the theoretical aspect of it that soundguruman does, but I know for a fact that anytime I've had a ceramic in a signal path I can get all kinds of weird noises and especially more hum that disappears when those ceramics are replaced. Not just old ones either. The only place I'll use them now is in locations where they are going to ground - doesn't seem to have the same effect.
    I love the Tung Sol 12AX7 tubes, and I think they sound fantastic, but I have had a lot of problems the past year finding quiet ones to use in V1: problems with humming and problems with microphonics. Really, I think the quietest new 12AX7 tubes on a consistent basis are the JJ, but they don;t seem to have quite the "life" in them that some of the other new tubes have (I don;t mean longevity, I mean in reference to the sound).
  21. #21
    Jun 2010
    U.S.A.
    4,441
    Question:
    Are the Shorter Plate 12AX7s Quieter?
    Is that's to be my Take from this Thread.
    So far I'm still about where I started.
    I have spent low and high amounts on different ones, and so Far seems to be a Crap Shoot.
    I do like the texture and tone of the Tung Sol's.
    B_T
    Keep Rockin!
    Terry
  22. #22
    May 2007
    pacific north west
    5,890
    I've had more hum problems with short plate tubes. Long plate tubes often seem to be brighter and/or higher gain so perhaps more hiss? I haven't noticed.
  23. #23
    Jul 2011
    California
    1,682
    The problem being that tiny amounts of inducted 60 cycle enter the signal path, especially in the first gain stage.
    This is amplified thousands of times, and ends up as 60 cycle hum in the final product.
    By eliminating or reducing that 60 cycle, even by a small amount, the amp produces a much more pleasing result.
    Formally, amp makers paid no attention to this. Amps hummed, all of them.
    After all, it takes the highest setting of the O scope to even see a hint of this 60 cycle in the first gain stage.
    But, as we added more and more gain stages, the hum became louder and louder. We could no longer ignore the problem.
    We started out with DC heaters, like in the early hi fi designs. Look at the McIntosh tube preamp schematics.
    Then somebody, like PV, took the hint, they started using 1/2 wave rectification on the preamp tubes.
    This then progressed into full wave DC to heat the preamp tubes, look at the earlier Carvin amps.
    Now, about half the manufacturers out there are using DC heaters. Some have even started using non inductive components.
    It's about time that the manufacturers started paying attention to the signal to noise ratio.
    And others eliminated the low frequency response of the amplifier all together, just so the hum would not be passed to the output.
    But still there is no high gain low noise amplifier for guitar-you are going to see that arrive, somebody is going to take the hint.
    And then if you have a classic amp, like a black face, silver face, there is a hum in it, that Fender ignored. The gain was not high enough to be bothered by the problem.
    But the hum can be reduced by installing silver mica caps, and the difference is measurable, if you care to measure it.
    You find a tech that plays guitar, instead of just working on amplifiers, you are headed in the right direction.
    The ones who do not play the guitar are oblivious to the problem. They see the amp as "working" or "non-working" they do not see the subtle differences in noise and performance.
    It takes a musician to hear the difference....although it is measurable, these measurements are typically ignored. To the uninitiated, it make no difference.
    It's true that only the most critical listeners are bothered by this noise. The average Joe does not even notice it.
    But if it was in your Hi Fi amp, you would start to notice it.
    It's easy to theorize about common mode rejection, and why there "shouldn't" be noise in the stages. But it does not work out that way in a high gain amplifier. ANY 60 cycle source in the vicinity of the preamp is another potential source of noise.
    Just as the pickup in a stratocaster will induct hum from any 60 cycle source (including the amp power transformer), and introduce it into the signal path...(like electrical wires in the house wall, fluorescent lights)
    the parts in the amplifier will produce the very same results.
  24. #24
    Jul 2011
    California
    1,682
    The criteria is not that of musicians, this is the criteria of manufacturers.
    Sure, the common mode reduced the noise considerably, but not enough for a musician.
    NOW, remove the shielding from the input stage of your O scope. Does the 60 cycle hum bother you NOW?
    You are not listening to it, you are LOOKING at it!
    Just as all the interference screws up your O scope trace, the same problem is interfering with our music.
    You would not want an oscilloscope with 60 cycle bleeding into the waveform. I do not want 60 cycle bleeding into my music.
    Same thing folks, different application.
    NOW, remove the metal film resistors, and silver mica capacitors from the input of your oscilloscope.
    Install carbon film resistors and ceramic disk capacitors.
    Now turn your scope on, and tell me what the waveform looks like...
    Garbage?
    You want the lowest noise components in your oscilloscope. You want the cleanest waveform. Your O scope IS an amplifier.
    I want the lowest noise components in MY amplifier too. I want clean, garbage free music.
    Both are amplifiers, both are artists, attempting to achieve a similar result!
    If we put the concept into terms that a technician can understand, prehaps we have achieved communication.
  25. #25
    Dec 2010
    861
    My interest in low noise is from the music production end, as a recording engineer for decades, design engineer and also having a large full service repair facility handling the work for many top selling artists. You never heard hum an any of my recordings, I would venture a guess, and I dare say we were more sensitive in a major league studio than a gigging guitarist would be.
    Noise is one of my interests and I am interested in data and reproducible experiments. Noise can be measured and is everyday in many fields where it is important. Dial in a wave analyzer and have lots of measurement headroom, which of course would be compromised by broadband noise on a scope.
    You made a statement that seemed counter intuitive and I asked for your measurement data. Do you have any, and under what conditions? Or is this claim anecdotal?
    I raise this because after years of debunking claims by "golden ears" in hi end hi-fi and music production, I hear claims that do not have supporting evidence, my curiosity is aroused. As I said, there are lots of reasons to avoid disc ceramic capacitors in signal chains for reasoned which have been measured but hum sensitivity is not one I have heard or measured.
    Your suggestions on how to show it "screws up the waveform" introduces a dozen or more uncontrolled variables so is no reason to attempt that when the hum pickup is actually quite well within range of the proper test instruments.
    "If we put the concept into terms that a technician can understand, prehaps we have achieved communication" Humm, I am a tech and a damn good one, also a degree'd engineer with design and patent-approved history....so why am I not seeing any thing convincing in your claim? Maybe I don't speak the right "technician" language.
  26. #26
    Jul 2011
    California
    1,682
    "As I said, there are lots of reasons to avoid disc ceramic capacitors in signal chains for reasoned which have been measured but hum sensitivity is not one I have heard or measured."
    You just learned another reason not to use them, I guess.
    I think I can explain it another way, the grid of the first gain stage is extremely sensitive.
    Just putting your hand in the vicinity of the grid or grid wire will produce a hum. This is why we need to use well shielded guitar cords. But anyway...
    So now I hook up a sensitive part (disk cap) to the grid. That part becomes essentially an antenna.
    Put your hand near that cap and you will get plenty loud hum.
    Now try the same with a silver mica cap. You will notice the immediate difference in sensitivity. It hardly cares at all what is in the vicinity, no hum, or greatly reduced sensitivity to external 60 cycle fields.
    It's the construction of the thing. Must be voodoo or something.
    I don't build them (the sm caps) , but I can tell the difference in performance.
  27. #27
    Dec 2010
    861
    Learn something from that? You must have a very low threshold of analyzing evidence.
    So you have no controlled measurements to show that your claim that these caps are sensitive to electro-magnetic fields. By your logic, all wires need to be eliminated because they are much more sensitive than any capacitor for fields surrounding because the cap has a high reactance and has self sheilding by design. You suggest greatly increasing the field strength by introducing a large antenna to the immediate area.
    Mounting position and lead length are factors that make a larger difference in field sensitivity, just like every passive part, so tiny differences in mounting position, height over the chassis, proximity to field generators, such as poorly twisted heater leads running too close.
    These caps do contribute to inter-modulation distortion however due to piezioelectric effects with ceramic. But that is to be avoiding in reproduction, but is not nessilarily a bad thing in production of music where distortion is needed to create a complex tone from a dominate fundamental. We use tubes due to their distortion character, not because they are hi-fi. They can be hi-fi to the input signal but not run in the wide range of drive and output swing used in guitar amps. A very clean amp is almost unusable for music production and you know that. That is why the caps are not used by designers of audio gear, but are used by MI designers. They do sound different and that might be just what the designer wanted as part of their tone signature. Hum and noise pickup by any design or measurement criteria is insignificant and swamped by noise induction mechanism that ARE present. Unbalanced chassis current flow, unbalanced heater wiring, parts placements, transformer design and orientation and many more factors are all orders of magnitude higher amplitude hum sources. Mentioning the guitar cable was a redherring, as you know a cable has higher delta capacitance than any fixed cap, due to cable movement, they are micro-phonic machines, translating mechanical movement of the proximity of the core to shield into a modulated shunt capacitance. The delta C will be in normal use, greater than any variability of fixed caps.
    All caps have some short comings but some of those are useful in creating a unique sound. Electrolytics are often given a bad rap as path components but their self shielding character, and unique signal influence on asymetrical waveforms can be just what a designer with a goal of a particular tone might seek.
    A designer should understand the fundamentals plus dynamic variables of components at their disposal when designing for a specific intended goal. Without understanding the real nature of the parts available and their influence on the outcome, creating an amp that sounds like intended would be relying on magic and legends but mostly luck if the results are near the goal. If you need the influences on signal that ceramic caps impart,, and which design of the caps have what characteristics, by all means use them because of them fitting goal, but to discount them due to internet myth and unproven claims is shrinking the toolbox a designer has to use in accomplishing the intended goal. It is not voodoo except for people without the facts and theory. For them, anything can be magic...airplanes and TV remote controls are surely mysterious things for some that only magic or gods could be the cause. High end hi-fi and hobbyist guitar amp discussions usually center around unproven myth and magic. Isolate, measure, understand.
  28. #28
    Supporting Member Alex R's Avatar
    Mar 2007
    UK
    1,127
    The '12AX7B' Chinese tubes, sold as specially selected for balance and low noise, are useful to have around, I find, for these problem amps that are just a bit too noisy. They have definitely reduced hum and hiss in a number of amps for me when in the first/second stage. I keep a stock of the standard Chinese 12AX7, and a handful of the 12AX7B for this particular issue.
    I too am a bit mystified by the idea that ceramic caps are specially bad for picking up atmospheric noise. Film caps and resistors do it too, as does everything in the signal path that gets amplified a lot. In quite a few years of passing my hands over the insides of amps to look for induced noise I haven't noticed ceramics being any worse for that than any other component. I have found and replaced quite a few film caps that have begun to pick up enough induced noise to cause oscillation - found one in a Roland Bolt only last week - but not a ceramic yet. I wonder whether the film wraps start to loosen up and make microscopic physical responses to induced AC, as these failing caps are also noisy when tapped.
  29. #29
    Dec 2008
    Wernersville, PA
    5,369
    I have never understood the failure mechanism in old film caps.
    The ones that are noisy when tapped "leak" Vdc when tapped.
    Maybe the film does break down.
  30. #30
    Jul 2011
    California
    1,682
    That's OK, you can build amps that hum, if you want to.
    But you are still looking at it like a technician, not as a guitar player...
    Guitar amp has thousands of times more gain than any other conventional audio equipment.
    You are still looking at the guitar amp as audio equipment. When you consider the gain, it's no longer conventional.
    There is enough gain to drive the amp into non-linear operation, where the stages are no longer inverting or non inverting. The gain is what you are missing...
    This amount of gain will make the smallest little noise-- very loud at the output. 1/2 mv of hum in the first stage is quite loud in the speakers, although it's almost too small to measure with your test equipment.
    In a Marshall, 1/2 mv audio input is supposed to drive the amp to clipping, or so say the engineers at the marshall factory. When you have an amp that is this sensitive, you start nit-picking the noise sources. That's what you are missing.
  31. #31
    Jul 2011
    California
    1,682
    Quote Originally Posted by Jazz P Bass View Post
    Yes, the insulation breaks down.
    But in between, they reach a point where they leak just a little tiny bit. The leakage occurs just when a note is played.
    This is when the capacitor is "ripe" and the amp sounds killer. The tiny leakage makes the sustain much better for guitar.
    The effect does not last, the cap eventually starts to leak more, and spoils the sound.
    This is why people think that NOS caps sound better. They do temporarily, in that "ripe" stage.
  32. #32
    Mar 2007
    UK
    1,127
    That's a new one on me, and I thought I'd heard em all.
  33. #33
    Dec 2008
    Wernersville, PA
    5,369
    Quote"1/2 mv of hum in the first stage is quite loud in the speakers, although it's almost too small to measure with your test equipment."
    Why can the hum voltage not be tested.
    If it is loud, then you can measure it.
    My "ballpark" criteria is 4 mVac hum on the output.
    Measured with a Fluke meter.
    Anything more & something is wrong.
  34. #34
    Jun 2010
    U.S.A.
    4,441
    Can you elaborate where and how you measure this on the output with a VOM?
    B_T
    Keep Rockin!
    Terry
  35. #35
    Dec 2010
    861
    I think voo-doo has taking over from engineering.....
    People think NOS caps sound better because they are told that and pass on the rumor. The "fact" becomes critical mass before anyone tests the claims. By that time, it is so well "known" that testing is not needed or results accepted. Read how some people on this forum wax poetically about subjective descriptions of various vacuum tubes as having characteristics that tubes can't have.
    Again only true believers can understand or appreciate the invisible qualities.
    It is not surprising that few objective tests are done, believers do not need proof. It is more than convenient for the sellers of magic that listening tests are subjective with no controls, and worst, not continuity. The flimflam artists know a little about human perception, one being that the believers do not know about human perception. For example most subjective opinions about a phenomena is memory of the conclusion, not memory of the experience. For example different senses have different memory methods. Smell has very long term, permanent memory yet tastes does not. Professional smell testers for foods and perfumes do not require clear references compare against. Smells can be remembered in their original emotional context years or decades later.....ever walk down the street and catch a whiff of aunt Mabel's peach pie cooling in the window and it all comes back vividly....yet Aunt Mabel died 30 years ago. Taste testers have to cleanse the mouth with water and refer to a taste standard within 1-2 seconds of sampling an unknown or their accuracy drops to unusable. Melody and rhythm have similar memory differences. A melody can be altered in every way, instrumentation, key, tempo and it will be recognized almost for ever regardless... as proven by millions of elevators playing background much that is recognized as Beatles tunes instantly but no component part is the same. A rhythm can be altered slightly and not recognized and a much shorter period. Our memory of, say a meal, is not of how it tastes...we can't remember that, but we do remember our impression of it and give reviews based on our memory of our impressions but not the actual tastes. Sound system testing falls in this latter category, we remember impressions but do not remember the sound. When swapping tubes, the delay in the heater coming up to full emission makes any comparison unreliable in the extreme. What makes guitar players most unreliable testers is that they are part of the feedback loop, where minute differences in pressure on strings and timing can swamp any minor differences in tubes. Removing any of those variables results in much more ambiguous results. The salesmen and flimflam artists know this but the users only want to believe so are quite sure of themselves after uncontrolled subjective tests. Ask a speaker salesman in a shop, what sells better, the more accurate speaker or louder speaker. They know they can sell a customer any model on the floor if they audition it 1 db louder than the rest. That sort of misleading approach apparently has entered pro audio and MI much to many our regrets.
    But its a living.
  1. ho HUM... hum is driving me nuts
    By vaughandy in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-05-2011, 07:48 PM
  2. Fender Twin Hum Hum Hum
    By teepeeasel in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-06-2010, 05:00 PM
  3. Mesa Lonestar hum(generally about hum)
    By Stretto in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-22-2009, 08:18 PM
  4. Musicman trouble shooting has caused hum, and only hum.
    By Gaz in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-10-2009, 12:53 AM
  5. SE el84 triode wired=hum as pentode=no hum ?
    By walkman in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-24-2008, 02:54 AM
